Hi:
Using large size Arc and Slider in tabview, and enable lv_obj_set_drag_parent. (LVGL V7.10)
When turning pages, if you touch Arc, the value of Arc will be changed. It should not have changed.
Sometimes touching arc will cause page turning. It was supposed to change the value of arc instead of turning the page.
LVGL V7.10
1.Touch page turning does not change the value of Arc and Slider.
2.When you touch to change the values of the arc and slider, the page will not turn.
/Create a test/
lv_obj_t* arc;
lv_obj_t* arc_label;
uint16_t arcValue;
void arc_event_cb(lv_obj_t* obj, lv_event_t event)
if (event == LV_EVENT_VALUE_CHANGED)
arcValue = lv_arc_get_value(arc);
uint8_t DataBuff[10];
sprintf(DataBuff, “%d”, arcValue);
lv_label_set_text(arc_label, DataBuff);//
void lv_tabview_Arc_Test(void)/////////////////////////////////////////////////
/Create a Tab view object/
lv_obj_t* tabview;
tabview = lv_tabview_create(lv_scr_act(), NULL);
lv_tabview_set_btns_pos(tabview, LV_TABVIEW_TAB_POS_NONE);/* Hide */
/*Add 3 tabs (the tabs are page (lv_page) and can be scrolled*/
lv_obj_t* tab1 = lv_tabview_add_tab(tabview, "Tab 1");
lv_obj_t* tab2 = lv_tabview_add_tab(tabview, "Tab 2");
lv_obj_t* tab3 = lv_tabview_add_tab(tabview, "Tab 3");
/*Add content to the tabs*/
lv_obj_t* label = lv_label_create(tab1, NULL);
lv_label_set_text(label, "This the first tab\n\n");
lv_obj_align(label, NULL, LV_ALIGN_IN_TOP_MID, 0, 20);
/*Create an Arc*/
arc = lv_arc_create(tab1, NULL);
lv_obj_set_size(arc, 460, 460);
lv_arc_set_rotation(arc, 90);
lv_arc_set_bg_angles(arc, 0, 360);
lv_arc_set_value(arc, 50);
lv_obj_align(arc, NULL, LV_ALIGN_CENTER, 0, 0);
lv_arc_set_adjustable(arc, true);//
lv_obj_set_drag_parent(arc, true);
lv_obj_set_event_cb(arc, arc_event_cb);//
arc_label = lv_label_create(tab1, NULL);
sprintf(DataBuff, "%d", arcValue);
lv_obj_align(arc_label, arc, LV_ALIGN_CENTER, 0, 0);
label = lv_label_create(tab2, NULL);
lv_label_set_text(label, "Second tab");
/*Create an Slider*/
lv_obj_t* slider = lv_slider_create(tab2, NULL);
lv_obj_set_size(slider, 460, 50);
lv_slider_set_range(slider, 0, 100);//
lv_slider_set_value(slider, 50, LV_ANIM_OFF);
lv_obj_align(slider, NULL, LV_ALIGN_CENTER, 0, 0);
lv_obj_set_drag_parent(slider, true);
label = lv_label_create(tab3, NULL);
lv_label_set_text(label, "Third tab");
