I would like the user to be able to sort items in a list by selecting an item and moving it up or down one (or more) positions.
Using the functions lv_obj_move_foreground and lv_obj_move_background, you can move an item in a list to the first or last postion.
I would like to have a function added that swaps item[n] and item[n+1] or exchange items [n] and [m].
I created a c function, but to be able to use this functionality in MicroPython it probably should be part of the lvgl library
lv_obj_swap function
// #define MY_CLASS &lv_obj_class
static void lv_obj_swap(lv_obj_t* obj1, lv_obj_t* obj2)
LV_ASSERT_OBJ(obj1, MY_CLASS)
LV_ASSERT_OBJ(obj2, MY_CLASS)
lv_obj_t* parent = lv_obj_get_parent(obj1);
lv_obj_t* parent2 = lv_obj_get_parent(obj2);
LV_ASSERT(parent == parent2);
uint_fast32_t index1 = lv_obj_get_child_id(obj1);
uint_fast32_t index2 = lv_obj_get_child_id(obj2);
parent->spec_attr->children[index1] = obj2;
parent->spec_attr->children[index2] = obj1;
lv_event_send(parent, LV_EVENT_CHILD_CHANGED, obj2);
lv_event_send(parent, LV_EVENT_CHILD_CHANGED, obj1);
lv_obj_invalidate(parent);
static void lv_obj_swap_children(lv_obj_t* parent, uint32_t child1, uint32_t child2)
LV_ASSERT_OBJ(parent, MY_CLASS);
uint32_t cnt = lv_obj_get_child_cnt(parent);
LV_ASSERT(cnt > child1);
LV_ASSERT(cnt > child2);
lv_obj_t* obj1 = parent->spec_attr->children[child1];
lv_obj_t* obj2 = parent->spec_attr->children[child2];
parent->spec_attr->children[child1] = obj2;
parent->spec_attr->children[child2] = obj1;
Sample application
static lv_obj_t* list2;
static lv_obj_t* buttonColumn;
static lv_obj_t* currentButton = NULL;
static lv_obj_t* btnUp;
static lv_obj_t* btnDn;
static void event_handler(lv_event_t* e)
if (code == LV_EVENT_CLICKED)
LV_LOG_USER("Clicked: %s", lv_list_get_btn_text(list2, obj));
if (currentButton == obj)
lv_obj_add_state(btnUp, LV_STATE_DISABLED);
lv_obj_add_state(btnDn, LV_STATE_DISABLED);
currentButton = obj;
lv_obj_t* parent = lv_obj_get_parent(obj);
uint32_t i;
for (i = 0; i < lv_obj_get_child_cnt(parent); i++)
lv_obj_t* child = lv_obj_get_child(parent, i);
if (child == currentButton)
lv_obj_add_state(child, LV_STATE_CHECKED);
lv_obj_clear_state(child, LV_STATE_CHECKED);
static void event_handler_mu(lv_event_t* e)
// lv_obj_t* obj = lv_event_get_target(e);
if ((code == LV_EVENT_CLICKED) || (code == LV_EVENT_LONG_PRESSED_REPEAT))
if (currentButton == NULL) return;
lv_obj_t* parent = lv_obj_get_parent(currentButton);
uint_fast32_t i = lv_obj_get_child_id(currentButton);
if (i > 0)
//lv_obj_swap(parent->spec_attr->children[i], parent->spec_attr->children[i - 1]);
lv_obj_swap_children(parent, i, i - 1);
static void event_handler_dn(lv_event_t* e)
if (i < lv_obj_get_child_cnt(parent) - 1)
//lv_obj_swap(parent->spec_attr->children[i], parent->spec_attr->children[i + 1]);
lv_obj_swap_children(parent, i, i + 1);
void lv_example_list_2(void)
/*Create a list*/
list2 = lv_list_create(lv_scr_act());
lv_obj_set_size(list2, lv_obj_get_width(lv_scr_act()) - 90, lv_obj_get_height(lv_scr_act()) - 10);
lv_obj_set_align(list2, LV_ALIGN_TOP_LEFT);
lv_obj_set_pos(list2, 5, 5);
lv_obj_set_flex_flow(list2, LV_FLEX_FLOW_COLUMN);
/*Add buttons to the list*/
lv_obj_t* btn;
for (int i = 0; i < 10; i++)
char szBuf[100];
sprintf(szBuf, " Item %d ", i);
btn = lv_btn_create(list2);
lv_obj_t* lab = lv_label_create(btn);
lv_label_set_text(lab, szBuf);
lv_obj_add_event_cb(btn, event_handler, LV_EVENT_CLICKED, NULL);
buttonColumn = lv_obj_create(lv_scr_act());
lv_obj_set_size(buttonColumn, 80, lv_obj_get_height(list2));
lv_obj_set_align(buttonColumn, LV_ALIGN_TOP_RIGHT);
lv_obj_set_pos(buttonColumn, -5, 5);
lv_obj_set_flex_flow(buttonColumn, LV_FLEX_FLOW_COLUMN);
btnUp = lv_list_add_btn(buttonColumn, LV_SYMBOL_UP, NULL);
lv_obj_add_event_cb(btnUp, event_handler_mu, LV_EVENT_ALL, NULL);
btnDn = lv_list_add_btn(buttonColumn, LV_SYMBOL_DOWN, NULL);
lv_obj_add_event_cb(btnDn, event_handler_dn, LV_EVENT_ALL, NULL);
but it probably will take a few hours.
