Support vertical switches
Currently, only horizontal switches are supported.
It would be nice to also have vertical switches for space-constrained UIs.
lv_obj_set_style_transform_angle(sw, 900, LV_PART_MAIN);
I was told “rotating widgets requires enabling some options and is quite memory hungry”.
In any case, I’m building my UI using EEZ Studio. When you use transformations like that, positioning the widget becomes a nightmare, since the program still considers the original widget size and position for sizing and positioning. In other words, the rectangle around the widget representing it’s shape doesn’t change.
  • @file lv_sw.c
  •  INCLUDES
#include “lv_vertical_switch.h”
#if LV_USE_VERTICAL_SWITCH != 0
#include “…/misc/lv_assert.h”
#include “…/misc/lv_math.h”
#include “…/misc/lv_anim.h”
#include “…/core/lv_indev.h”
#include “…/core/lv_disp.h”
#include “lv_img.h”
  •  DEFINES
#define MY_CLASS &lv_vertical_switch_class
#define LV_VERTICAL_SWITCH_IS_ANIMATING(sw) (((sw)->anim_state) != LV_VERTICAL_SWITCH_ANIM_STATE_INV)
/** Switch animation start value. (Not the real value of the switch just indicates process animation)*/
#define LV_VERTICAL_SWITCH_ANIM_STATE_START 0
/** Switch animation end value. (Not the real value of the switch just indicates process animation)*/
#define LV_VERTICAL_SWITCH_ANIM_STATE_END 256
/** Mark no animation is in progress*/
#define LV_VERTICAL_SWITCH_ANIM_STATE_INV -1
  •  TYPEDEFS
  • STATIC PROTOTYPES
    static void lv_vertical_switch_constructor(const lv_obj_class_t * class_p, lv_obj_t * obj);
    static void lv_vertical_switch_destructor(const lv_obj_class_t * class_p, lv_obj_t * obj);
    static void lv_vertical_switch_event(const lv_obj_class_t * class_p, lv_event_t * e);
    static void draw_main(lv_event_t * e);
static void lv_vertical_switch_anim_exec_cb(void * sw, int32_t value);
static void lv_vertical_switch_trigger_anim(lv_obj_t * obj);
static void lv_vertical_switch_anim_ready(lv_anim_t * a);
  • STATIC VARIABLES
    const lv_obj_class_t lv_vertical_switch_class = {
    .constructor_cb = lv_vertical_switch_constructor,
    .destructor_cb = lv_vertical_switch_destructor,
    .event_cb = lv_vertical_switch_event,
    .width_def = (4 * LV_DPI_DEF) / 5,
    .height_def = (4 * LV_DPI_DEF) / 15,
    .group_def = LV_OBJ_CLASS_GROUP_DEF_TRUE,
    .instance_size = sizeof(lv_vertical_switch_t),
    .base_class = &lv_obj_class
  •  MACROS
  • GLOBAL FUNCTIONS
lv_obj_t * lv_vertical_switch_create(lv_obj_t * parent)
LV_LOG_INFO(“begin”);
lv_obj_t * obj = lv_obj_class_create_obj(MY_CLASS, parent);
lv_obj_class_init_obj(obj);
return obj;
  • STATIC FUNCTIONS
LV_UNUSED(class_p);
LV_TRACE_OBJ_CREATE(“begin”);
lv_vertical_switch_t * sw = (lv_vertical_switch_t *)obj;
sw->anim_state = LV_VERTICAL_SWITCH_ANIM_STATE_INV;
lv_obj_clear_flag(obj, LV_OBJ_FLAG_SCROLLABLE);
lv_obj_add_flag(obj, LV_OBJ_FLAG_CHECKABLE);
lv_obj_add_flag(obj, LV_OBJ_FLAG_SCROLL_ON_FOCUS);
LV_TRACE_OBJ_CREATE("finished");
LV_UNUSED(class_p);
lv_anim_del(sw, NULL);
LV_UNUSED(class_p);
lv_res_t res;
/*Call the ancestor's event handler*/
res = lv_obj_event_base(MY_CLASS, e);
if(res != LV_RES_OK) return;
if(code == LV_EVENT_REFR_EXT_DRAW_SIZE) {
    lv_coord_t knob_left = lv_obj_get_style_pad_left(obj,   LV_PART_KNOB);
    lv_coord_t knob_right = lv_obj_get_style_pad_right(obj,  LV_PART_KNOB);
    lv_coord_t knob_top = lv_obj_get_style_pad_top(obj,    LV_PART_KNOB);
    lv_coord_t knob_bottom = lv_obj_get_style_pad_bottom(obj, LV_PART_KNOB);
    /*The smaller size is the knob diameter*/
    lv_coord_t knob_size = LV_MAX4(knob_left, knob_right, knob_bottom, knob_top);
    knob_size += _LV_VERTICAL_SWITCH_KNOB_EXT_AREA_CORRECTION;
    knob_size += lv_obj_calculate_ext_draw_size(obj, LV_PART_KNOB);
    lv_coord_t * s = lv_event_get_param(e);
    *s = LV_MAX(*s, knob_size);
    *s = LV_MAX(*s, lv_obj_calculate_ext_draw_size(obj, LV_PART_INDICATOR));
else if(code == LV_EVENT_VALUE_CHANGED) {
    lv_vertical_switch_trigger_anim(obj);
    lv_obj_invalidate(obj);
else if(code == LV_EVENT_DRAW_MAIN) {
    draw_main(e);
lv_draw_ctx_t * draw_ctx = lv_event_get_draw_ctx(e);
/*Calculate the indicator area*/
lv_coord_t bg_left = lv_obj_get_style_pad_left(obj,     LV_PART_MAIN);
lv_coord_t bg_right = lv_obj_get_style_pad_right(obj,   LV_PART_MAIN);
lv_coord_t bg_top = lv_obj_get_style_pad_top(obj,       LV_PART_MAIN);
lv_coord_t bg_bottom = lv_obj_get_style_pad_bottom(obj, LV_PART_MAIN);
/*Draw the indicator*/
/*Respect the background's padding*/
lv_area_t indic_area;
lv_area_copy(&indic_area, &obj->coords);
indic_area.x1 += bg_left;
indic_area.x2 -= bg_right;
indic_area.y1 += bg_top;
indic_area.y2 -= bg_bottom;
lv_draw_rect_dsc_t draw_indic_dsc;
lv_draw_rect_dsc_init(&draw_indic_dsc);
lv_obj_init_draw_rect_dsc(obj, LV_PART_INDICATOR, &draw_indic_dsc);
lv_draw_rect(draw_ctx, &draw_indic_dsc, &indic_area);
/*Draw the knob*/
lv_coord_t anim_value_y = 0;
lv_coord_t knob_size = lv_obj_get_width(obj);
lv_coord_t anim_length = lv_area_get_height(&obj->coords) - knob_size;
if(LV_VERTICAL_SWITCH_IS_ANIMATING(sw)) {
    /* Use the animation's coordinate */
    anim_value_y = (anim_length * sw->anim_state) / LV_VERTICAL_SWITCH_ANIM_STATE_END;
else {
    /* Use LV_STATE_CHECKED to decide the coordinate */
    bool chk = lv_obj_get_state(obj) & LV_STATE_CHECKED;
    anim_value_y = chk ? anim_length : 0;
//if(LV_BASE_DIR_RTL == lv_obj_get_style_base_dir(obj, LV_PART_MAIN)) {
//    anim_value_y = anim_length - anim_value_y;
lv_area_t knob_area;
knob_area.y1 = obj->coords.y1 + anim_value_y;
knob_area.y2 = knob_area.y1 + knob_size;
knob_area.x1 = obj->coords.x1;
knob_area.x2 = obj->coords.x2;
/*Apply the paddings on the knob area*/
knob_area.x1 -= knob_left;
knob_area.x2 += knob_right;
knob_area.y1 -= knob_top;
knob_area.y2 += knob_bottom;
lv_draw_rect_dsc_t knob_rect_dsc;
lv_draw_rect_dsc_init(&knob_rect_dsc);
lv_obj_init_draw_rect_dsc(obj, LV_PART_KNOB, &knob_rect_dsc);
lv_draw_rect(draw_ctx, &knob_rect_dsc, &knob_area);
static void lv_vertical_switch_anim_exec_cb(void * var, int32_t value)
lv_vertical_switch_t * sw = var;
sw->anim_state = value;
lv_obj_invalidate((lv_obj_t *)sw);
  • Resets the switch’s animation state to “no animation in progress”.
    lv_vertical_switch_t * sw = a->var;
  • Starts an animation for the switch knob. if the anim_time style property is greater than 0
  • @param obj the switch to animate
    LV_ASSERT_OBJ(obj, MY_CLASS);
    uint32_t anim_dur_full = lv_obj_get_style_anim_time(obj, LV_PART_MAIN);
    if(anim_dur_full > 0) {
    int32_t anim_start;
    int32_t anim_end;
    /No animation in progress → simply set the values/
    if(sw->anim_state == LV_VERTICAL_SWITCH_ANIM_STATE_INV) {
    anim_start = chk ? LV_VERTICAL_SWITCH_ANIM_STATE_START : LV_VERTICAL_SWITCH_ANIM_STATE_END;
    anim_end = chk ? LV_VERTICAL_SWITCH_ANIM_STATE_END : LV_VERTICAL_SWITCH_ANIM_STATE_START;
    /Animation in progress. Start from the animation end value/
    else {
    anim_start = sw->anim_state;
    /Calculate actual animation duration/
    uint32_t anim_dur = (anim_dur_full * LV_ABS(anim_start - anim_end)) / LV_VERTICAL_SWITCH_ANIM_STATE_END;
     /*Stop the previous animation if it exists*/
     lv_anim_t a;
     lv_anim_init(&a);
     lv_anim_set_var(&a, sw);
     lv_anim_set_exec_cb(&a, lv_vertical_switch_anim_exec_cb);
     lv_anim_set_values(&a, anim_start, anim_end);
     lv_anim_set_ready_cb(&a, lv_vertical_switch_anim_ready);
     lv_anim_set_time(&a, anim_dur);
     lv_anim_start(&a);
  • @file lv_switch.h
#ifndef LV_VERTICAL_SWITCH_H
#define LV_VERTICAL_SWITCH_H
#ifdef __cplusplus
extern “C” {
  •  INCLUDES
#include “…/lv_conf_internal.h”
#include “…/core/lv_obj.h”
  •  DEFINES
/** Switch knob extra area correction factor */
#define _LV_VERTICAL_SWITCH_KNOB_EXT_AREA_CORRECTION 2
  •  TYPEDEFS
typedef struct {
lv_obj_t obj;
int32_t anim_state;
} lv_vertical_switch_t;
extern const lv_obj_class_t lv_vertical_switch_class;
  • GLOBAL PROTOTYPES
  • Create a vertical switch object
  • @param parent pointer to an object, it will be the parent of the new switch
  • @return pointer to the created switch
    lv_obj_t * lv_vertical_switch_create(lv_obj_t * parent);
  •  MACROS
#endif /LV_USE_VERTICAL_SWITCH/
#ifdef __cplusplus
} /extern “C”/
#endif /LV_VERTICAL_SWITCH_H/
I modified the switch a little bit. You need to add the macro definition LV_USE_VERTICAL_SWITCH in lv_conf.h, which can realize a vertical switch.
Because I didn’t set a default style, it is transparent when created
Here is an example
int app_obj_2(lv_obj_t parent)
lv_obj_t
vertical_sw = lv_vertical_switch_create(parent);
lv_obj_set_style_bg_color(vertical_sw, lv_color_make(0,0,0), LV_PART_MAIN);
lv_obj_set_style_bg_opa(vertical_sw, LV_OPA_COVER, LV_PART_MAIN);
lv_obj_set_style_radius(vertical_sw, LV_RADIUS_CIRCLE, LV_PART_MAIN);
lv_obj_set_style_bg_color(vertical_sw, lv_color_make(0, 0, 255), LV_PART_INDICATOR);
lv_obj_set_style_bg_opa(vertical_sw, LV_OPA_COVER, LV_PART_INDICATOR);
lv_obj_set_style_radius(vertical_sw, LV_RADIUS_CIRCLE, LV_PART_INDICATOR);
lv_obj_set_style_bg_color(vertical_sw, lv_color_make(255, 0, 0), LV_PART_KNOB);
lv_obj_set_style_bg_opa(vertical_sw, LV_OPA_COVER, LV_PART_KNOB);
lv_obj_set_style_radius(vertical_sw, LV_RADIUS_CIRCLE, LV_PART_KNOB);
lv_obj_set_size(vertical_sw, 50, 150);
lv_obj_center(vertical_sw);
return 0;
It seems like a reasonable update the the current switch widget. (I agree that rotation is not ideal here)
If you are open to add it, please open a pull request on GitHub. :pray:
