I have an LCD which uses RGB222 format (1 byte, 64 colors). I see that there’s not direct support in LVGL for this format. I wonder what would be the best way to support this particular format when using lv_color8_t datatype. I’m thinking the easiest would be to redefine all colors by forming an lv_color8_t with the expected format. In that case? How would I redefine every color which is used in the style?
I could do this programatically since it involves some simple bit shifting.
The alternative would be to do this on runtime inside the flush callback, but that would be really wasteful.
Also, what are the chances of adding this format to LVGL eventually? Would it collide too much with current interpretation of lv_color8_t? In my case the bits are padded to the left (MSB), I wonder if there could be a variation with the bits padded to the right, which would complicate things.
nRF52832 on NuttX, LCD7301 TFT LCD with transflective 176x176 64 color panel.
latest stable
Draw in RGB222 without wasting performance
Just planning still
N/A
N/A
