I am seeing some issues with some style properties of objects. The radius and gradient are not drawn at all. However, the properties seem to have been set correctly.
Other style properties (background color, border width/color) seem to work correctly.
I do not seem to find what causes this behavior. I have not manually set any default styles.
I don’t really know where else to look, or what mistakes I could be making.
Could anyone point me in the right direction?
ESP32 S3, TFT display X-NUCLEO-GFX01M1
8.3.7
I want to draw a simple rectangle, having a radius.
I tried setting the radius with lv_obj_set_style_radius(obj, value, 0).
After reading the property (lv_obj_get_style_radius), the value seems to be correct.
However, the rectangle on the screen does not show any radius whatsoever.
I also tried setting the radius by first defining a style:
static lv_style_t style;
lv_style_init(&style);
lv_style_set_radius(&style, LV_RADIUS_CIRCLE);
lv_obj_add_style(obj, &style, 0);
This again results in no radius to be seen on the screen.
lv_obj_t* obj = lv_obj_create(lv_scr_act());
lv_obj_set_style_bg_color(obj, lv_color_hex(0xFF0000), 0);
lv_obj_set_style_radius(obj, LV_RADIUS_CIRCLE, 0);
lv_obj_set_style_border_color(obj, lv_color_black(), 0);
lv_obj_set_style_border_width(obj, 3, 0);
lv_obj_center(obj);
Expected result: Red circle with black border.
Seen: Red box (no rounding whatsoever), with black border.
