Style with new font size is not working on lv_label objects
ESP32-C6 Dev Board
8.3.11 with esp_lvgl_port 1.4.0
i want to set the font size of a single label to “large!”
I enabled the large font in the menuconfig, initialized a new style, applied the font and applied the style to the label. the label did not change.
void create_ui_components(lv_disp_t *disp)
   <code ommitted...>
    lv_style_t style;
    lv_style_init(&style);
    lv_style_set_text_font(&style, &lv_font_montserrat_48);
    strcat(centerText, getOpModeString());
    strcat(centerText, " - ");
    strcat(centerText, getStatusString());
    status_label = lv_label_create(scr);
    lv_label_set_text(status_label, centerText);
    lv_obj_add_style(status_label, &style, 0); // <= i would expect this to work...
    lv_obj_align(status_label, LV_ALIGN_CENTER, 0, 0);
any ideas on what i’m doing wrong? it surely cannot be much…
thank you so much!
I dont know if you want to go down this route but I use:
lv_obj_set_style_text_font(status_label, &lv_font_montserrat_48, LV_PART_MAIN);
Hope this helps you in some way…
Or maybe you need to set the style then the text?
Regards
oh nice thank you, that solved it for me!
I still would be interested what i did originally wrong, but this issue is now resolved :slight_smile:
