Style used when button is pressed
I’m new to LVGL and I’m trying to draw a button with a particular behavior when pressed.
SDL
v8.2
I want to have a button with a text and a subtext. Once the button is pressed, the text and the subtext must not have the same color.
    static lv_obj_t * page = lv_obj_create(lv_scr_act());
    lv_obj_set_size(page, lv_pct(100), lv_pct(100));
    const lv_color_t red = lv_color_hex(0xff0000);
    const lv_color_t green = lv_color_hex(0x00ff00);
    const lv_color_t blue = lv_color_hex(0x0000ff);
    lv_style_t style1;
    lv_style_init(&style1);
    lv_style_set_bg_opa(&style1, LV_OPA_COVER);
    lv_style_set_bg_color(&style1, red);
    lv_style_set_pad_all(&style1, 5);
    lv_style_t style2;
    lv_style_init(&style2);
    lv_style_set_bg_opa(&style2, LV_OPA_COVER);
    lv_style_set_bg_color(&style2, green);
    lv_style_t style3;
    lv_style_init(&style3);
    lv_style_set_text_color(&style3, green);
    lv_style_t style4;
    lv_style_init(&style4);
    lv_style_set_text_color(&style4, red);
    lv_style_t style5;
    lv_style_init(&style5);
    lv_style_set_text_color(&style5, green);
    lv_style_t style6;
    lv_style_init(&style6);
    lv_style_set_text_color(&style6, blue);
    static lv_obj_t * btn1 = lv_btn_create(page);
    static lv_obj_t * label1 = lv_label_create(btn1);
    static lv_obj_t * label2 = lv_label_create(btn1);
    lv_obj_remove_style_all(btn1);
    lv_obj_add_style(btn1, &style1, LV_STATE_DEFAULT);
    lv_obj_add_style(btn1, &style2, LV_STATE_PRESSED);
    lv_obj_remove_style_all(label1);
    lv_obj_add_style(label1, &style3, LV_STATE_DEFAULT);
    lv_obj_add_style(label1, &style4, LV_STATE_PRESSED);
    lv_obj_remove_style_all(label2);
    lv_obj_add_style(label2, &style5, LV_STATE_DEFAULT);
    lv_obj_add_style(label2, &style6, LV_STATE_PRESSED);
    lv_label_set_text(label1, "Title");
    lv_label_set_text(label2, "Subtitle");
    lv_obj_center(btn1);
    lv_obj_align(label1, LV_ALIGN_CENTER, 0, -5);
    lv_obj_align_to(label2, label1, LV_ALIGN_OUT_BOTTOM_MID, 0, 5);
    lv_obj_set_size(btn1, LV_SIZE_CONTENT, LV_SIZE_CONTENT);
LV_STATE_DEFAULT:
LV_STATE_PRESSED:
The labels created inside the buttons will not receive the pressed state, therefore, the pressed style on the labels will not take effect
You can use the event trickle flag on the button, this sends the pressed state to the children
lv_obj_add_flag(btn1, LV_OBJ_FLAG_EVENT_TRICKLE);
