In v7 exist set outside margins for obj, howto do this in V8?
@kisvegabor is this in 8 replaced with
lv_obj_align_to(obj_to_align, obj_referece, LV_ALIGN_..., x, y)
or exist margins set as in 7 ?
I need place in parent more cild with defined spaces between objects. xy isnt good for this situation.
In v8 margin was really removed. You can do these instead:
- Set padding on the parent
- Use
lv_obj_set_style_translate_xto offset the widget - Use
lv_obj_align_toas @Marian_M suggested
Adding back margin was requested from several sources and it’s already added again in v9. We are planning to release v9 by the end of this year.
