currently working for a smart file manager GUI
i manage to build a simple GUI for file manager where i can access my SD card files using esp32 and SD card adapter.
ESP32 and ILI9341 Display
v7.0.x
how touch work properly after 10 clicks
implementation of simple GUI.
#include "GUI.h"
#include <SD.h>
#include <FS.h>
TFT_Gui dir;
String nextFile;
// TFT_eSPI tft = TFT_eSPI(); /* TFT instance */
static lv_color_t buf2[LV_HOR_RES_MAX * 10];
/* Display flushing */
void my_disp_flush(lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p) {
uint16_t c;
tft.startWrite(); /* Start new TFT transaction */
tft.setAddrWindow(area->x1, area->y1, (area->x2 - area->x1 + 1), (area->y2 - area->y1 + 1)); /* set the working window */
for (int y = area->y1; y <= area->y2; y++)
for (int x = area->x1; x <= area->x2; x++)
c = color_p->full;
tft.writeColor(c, 1);
color_p++;
tft.endWrite(); /* terminate TFT transaction */
lv_disp_flush_ready(disp); /* tell lvgl that flushing is done */
bool my_touchpad_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data) {
uint16_t touchX, touchY;
bool touched = tft.getTouch(&touchX, &touchY, 600U);
if (!touched){
// Serial.printf("touch false \r\n");
return false;
if (touchX > SCREEN_WIDTH || touchY > SCREEN_HIGHT) {
Serial.println("Y or y outside of expected parameters..");
Serial.print("y:");
Serial.print(touchX);
Serial.print(" x:");
Serial.print(touchY);
}else {
data->state = touched ? LV_INDEV_STATE_PR : LV_INDEV_STATE_REL;
/*Set the coordinates (if released use the last pressed coordinates)*/
data->point.x = touchX;
data->point.y = touchY;
Serial.printf(" data->point.x = %u \r\n",touchX);
Serial.printf(" data->point.y = %u \r\n",touchY);
return false; /*Return `false` because we are not buffering and no more data to read*/
void guiInIt() {
tft.begin(); /* TFT init */
tft.setRotation(1);
//uint16_t calData[5] = { 275, 3620, 264, 3532, 1 };
uint16_t calData[5] = {378U, 3539U, 743U, 2724U, 7U};
tft.setTouch(calData);
lv_disp_buf_init(&disp_buf, buf, buf2, LV_HOR_RES_MAX * 10);
/*Initialize the display*/
lv_disp_drv_t disp_drv;
lv_disp_drv_init(&disp_drv);
disp_drv.hor_res = SCREEN_WIDTH;
disp_drv.ver_res = SCREEN_HIGHT;
disp_drv.buffer = &disp_buf;
lv_indev_drv_t indev_drv;
lv_indev_drv_init(&indev_drv); /*Descriptor of a input device driver*/
indev_drv.type = LV_INDEV_TYPE_POINTER; /*Touch pad is a pointer-like device*/
indev_drv.read_cb = my_touchpad_read; /*Set your driver function*/
lv_indev_drv_register(&indev_drv); /*Finally register the driver*/
bool TFT_Gui::initSD() {
if (!SD.begin(SS)) {
return false;
return true;
String TFT_Gui::openFile(String filename) {
File file = SD.open(filename);
if (!file) {
file.close();
return "";
String textData;
while (file.available()) {
textData += char(file.read());
Serial.println(textData);
file.close();
return textData;
void TFT_Gui::lvErrorPage() {
lv_obj_t *label = lv_label_create(lv_scr_act(), NULL);
lv_label_set_text(label, "Please check your SD Card");
lv_obj_align(label, NULL, LV_ALIGN_CENTER, 0, 0);
void TFT_Gui::refreshList(String fileName) {
if (list != NULL) {
lv_list_clean(list);
File root = SD.open(fileName);
File file = root.openNextFile();
while (file) {
if(file.isDirectory()){
nextFile = file.name();
// Serial.printf("nextFile in file.isDirectory() = %s \r\n",nextFile.c_str());
int n = nextFile.lastIndexOf('/');
int m = nextFile.length();
String tempName = nextFile.substring(n ,m);
lv_obj_t * list_btn = lv_list_add_btn(list, LV_SYMBOL_DIRECTORY , (const char *)tempName.c_str());
// Serial.printf("next directory is %s \r\n",nextFile.c_str());
lv_obj_set_event_cb(list_btn, event_handler1);
} else {
String nextFile1 = file.name();
int n = nextFile1.lastIndexOf('/');
int m = nextFile1.length();
String tempName = nextFile1.substring(n ,m);
lv_list_add_btn(list, LV_SYMBOL_FILE , (const char *)tempName.c_str());
void TFT_Gui::createTab1(lv_obj_t *parent,String fileName)
//List Tab
lv_page_set_scrl_layout(parent, LV_LAYOUT_PRETTY_TOP);
list = lv_list_create(parent, NULL);
lv_obj_set_size(list, lv_obj_get_width(parent) - 20, lv_obj_get_height(parent) - 20);
lv_obj_align(list, NULL, LV_ALIGN_IN_TOP_LEFT, 10, 10);
refreshList(fileName);
void TFT_Gui::lv_file_browser(String fileName)
/* Create a window to use as the action bar */
win = lv_win_create(lv_scr_act(), NULL);
lv_obj_set_size(win, LV_HOR_RES, LV_VER_RES);
lv_win_set_title(win, "File Manager");
lv_obj_t * up_btn = lv_win_add_btn(win, LV_SYMBOL_UP);
lv_obj_set_event_cb(up_btn, go_up);
lv_obj_t * home = lv_win_add_btn(win, LV_SYMBOL_HOME);
lv_obj_set_event_cb(home, homeDir);
lv_obj_t * win_content = lv_win_get_content(win);
lv_cont_set_fit(lv_page_get_scrl(win_content), _LV_FIT_LAST);
/* Create the list */
main_list = lv_list_create(win, NULL);
/* Fit the list inside the page, taking into account any borders. */
lv_area_t page_area;
lv_obj_get_coords(win_content, &page_area);
lv_obj_get_inner_coords(win_content, &page_area);
lv_obj_set_size(main_list, lv_area_get_width(&page_area), lv_area_get_height(&page_area));
createTab1(main_list,fileName);
static void event_handler1(lv_obj_t * obj, lv_event_t event)
// Serial.printf("Clicked: %s\n", lv_list_get_btn_text(obj));
dir.lv_file_browser(nextFile);
static void homeDir(lv_obj_t * obj, lv_event_t event){
dir.lv_file_browser("/");
static void go_up(lv_obj_t * obj, lv_event_t event){
String backDir = nextFile.substring(0,n);
Serial.printf("len is %d and backDir is %s \r\n",n,backDir.c_str());
if (n==0) {
dir.lv_file_browser();
}else{
dir.lv_file_browser(backDir);
nextFile = backDir;
}https://drive.google.com/file/d/1smvZopkeD4diyPS0694ebLKFbd2Bg2Ql/view?usp=sharing
you can see at the and display got freeze
see this link
