Executing basic LVGL code (v8.3.6 from SquareLine) generate a StoreProhibited exception in function
static bool lv_timer_exec(lv_timer_t * timer) (file lv_timer.c) at line :
if(timer->timer_cb && original_repeat_count != 0) timer->timer_cb(timer);
Guru Meditation Error: Core 1 panic’ed (StoreProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x4011fc08 PS : 0x00060430 A0 : 0x800df4c2 A1 : 0x3ffb1c60
A2 : 0x00000000 A3 : 0x00000010 A4 : 0x00000320 A5 : 0x00000000
A6 : 0x00000000 A7 : 0x00000000 A8 : 0x4acf4acf A9 : 0x00004acf
A10 : 0x00000000 A11 : 0x0000031f A12 : 0x3ffc4224 A13 : 0x00000013
A14 : 0x00000004 A15 : 0x3ffc32a8 SAR : 0x00000012 EXCCAUSE: 0x0000001d
EXCVADDR: 0x00000000 LBEG : 0x4008788e LEND : 0x40087899 LCOUNT : 0x00000000
I’m using ESP32 with RA8875 and Arduino IDE 2.2.1
LVGL not crashing with basic code
In lv_conf.h I tried #define LV_TICK_CUSTOM with values 0 or 1 (and removing or adding lv_tick_inc() function in my code). Same result.
In lv_conf.h I tried to change #define LV_MEM_SIZE (48U * 1024U) with value 32U * 1024U. Same result.
It’s like if the lv_timer_t pointer was not initialized. Perhaps I have to add something in the code ?
I already spend a few days reading LVGL documentation and trying to understand why it is crashing.
Thank you very much for your help !
#include <lvgl.h>
#include <ui.h>
#include <stdint.h>
#include <SPI.h>
#include <Wire.h>
#include "Adafruit_GFX.h"
#include "Adafruit_RA8875.h"
//EP32 PINS
#define RA8875_INT 2
#define RA8875_CS 5
#define RA8875_RESET 4
#define RA8875_SCLK 18
#define RA8875_DO 19
#define RA8875_DI 23
#define GSL1680_WAKE 32
#define GSL1680_INT 33
hw_timer_t * timerTick = NULL; // Timer for LVGL Tick
//Screen size
static const uint16_t screenWidth = 800;
static const uint16_t screenHeight = 480;
Adafruit_RA8875 tft = Adafruit_RA8875(RA8875_CS, RA8875_RESET);
static lv_color_t *buf1 = (lv_color_t*) heap_caps_malloc(screenWidth * screenHeight / 10, MALLOC_CAP_SPIRAM );
#if LV_USE_LOG != 0
/* Serial debugging */
void my_print(const char * buf)
Serial.printf(buf);
Serial.flush();
void my_disp_flush(lv_disp_drv_t * disp, const lv_area_t * area, lv_color_t * color_p)
//Function I wrote for RA8875
lv_disp_flush_ready(disp); /* Indicate you are ready with the flushing*/
void my_touchpad_read(lv_indev_drv_t * indev_drv, lv_indev_data_t * data)
//Function I wrote for GSLX680 Touch pad
//Function for lv_tick_inc
static void lv_tick_handler()
lv_tick_inc(5);
void setup()
Serial.begin(115200);
SPI.begin(RA8875_SCLK, RA8875_DO, RA8875_DI, -1);
Wire.begin(); // join i2c bus (address optional for master)
while (!tft.begin(RA8875_800x480))
Serial.println("RA8875 Not Found!");
delay(100);
Serial.println("Found RA8875");
tft.displayOn(true);
tft.GPIOX(true); // Enable TFT - display enable tied to GPIOX
tft.PWM1config(true, RA8875_PWM_CLK_DIV1024); // PWM output for backlight
tft.PWM1out(255);
tft.fillScreen(RA8875_WHITE);
tft.graphicsMode();
timerTick = timerBegin(0, 80, true);
timerAttachInterrupt(timerTick, &lv_tick_handler, true);
timerAlarmWrite(timerTick, 5000, true); //5ms
timerAlarmEnable(timerTick);
#if LV_USE_LOG != 0
lv_log_register_print_cb( my_print ); /* register print function for debugging */
lv_disp_draw_buf_init(&draw_buf, buf1, NULL, screenWidth * screenHeight / 10); //Initialize the display buffer.
/*Initialize the display*/
static lv_disp_drv_t disp_drv; /*Descriptor of a display driver*/
lv_disp_drv_register( &disp_drv );
lv_indev_drv_init( &indev_drv );
lv_indev_drv_register( &indev_drv );
ui_init();
void loop()
lv_timer_handler(); // let the GUI do its work
delay(5);
