H7 has hardware JPEG encoder and decoder, can I use STM32 hardware encoder instead of LVGL’s built-in encoder when using picture controls
H743 Mini custom version, MCU only
ILI9341 2.4-inch screen 320*240 SPI
LVGL-master LVGL-v8.1
Use the external JPG codec instead of the built-in one
Nothing. I don’t know how to do that
As described in docs jpg decoder enabled by
enabled in lv_conf.h by LV_USE_SJPG
So exclude LV_USE_SJPG from lv_conf.h. But you should write and register your own decoder which would use STM32-hardware instead of soft.
EDIT: as far as I understand the main purpose of the decoder is to open an image, decode it and transmit raw-data for processing to the image-widget functions.
EDIT2: as an example of decoder you can see sources of lv_lib_jpg decoder. Use hardware capabilities inside decoder_info(), decoder_open(), decoder_read_line()
