STM32H7 LTDC + DMA2D + SDRAM High CPU usage
High CPU usage while updating basic arcs and sliders.
Custom stm32h743, compiler GCC and makefile
Current master
Improve FPS and cpu usage.
Checking if DMA2D is working, working out the best SDRAM timing and CLK.
If i adjust the sleep in the GFX thread to a lower value it causes the fps to go down significantely and cpu usage to spike up to 95-99% (20-24fps). Also I’ve noticed that using buffers below 50% of the screen size impacts the performance while those above 50% dont affect it at all.
As for the driver im using the LTDC lvgl driver with some adjustment done by me for usage with ChibiOS.
#include "ch.h"
#include "hal.h"
#include "lvgl_thread.h"
#include <string.h>
#include "lvgl/lvgl.h"
#include "ui/ui.h"
#include "chprintf.h"
#include "nxrd.h"
uint8_t frame_buffer1[600 * 1024 * 2] __attribute__((section(".sdram"), aligned(1)));
uint8_t frame_buffer_optional[600 * 1024 * 2] __attribute__((section(".sdram"), aligned(1)));
static THD_WORKING_AREA(waLV_TIMER_HANDLER, 4096);
static THD_FUNCTION(LV_TIMER_HANDLER, arg)
    (void)arg;
    chRegSetThreadName("LV_TIMER_HANDLER");
    uint32_t sleep = 0;
    while (true)
        sleep = lv_timer_handler();
        if (sleep == LV_NO_TIMER_READY)
            sleep = LV_DEF_REFR_PERIOD;
        if (sleep <= 0)
            sleep = 1;
        chThdSleepMilliseconds(sleep);
static THD_WORKING_AREA(waLV_GFX, 4096);
static THD_FUNCTION(LV_GFX, arg)
    (void)arg;
    chRegSetThreadName("LV_GFX_HANDLER");
    lv_lock();
    lv_obj_t *screen = lv_obj_create(lv_scr_act());
    lv_obj_set_size(screen, 1024, 600);
    lv_obj_set_style_bg_color(screen, lv_color_black(), LV_PART_MAIN | LV_STATE_DEFAULT);
    lv_obj_set_style_border_width(screen, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
    lv_obj_set_style_radius(screen, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
    lv_obj_t *splash = lv_image_create(screen);
    lv_image_set_src(splash, getimage());
    lv_obj_align(splash, LV_ALIGN_CENTER, 0, 0);
    lv_unlock();
    chThdSleepMilliseconds(3000);
    lv_lock();
    lv_obj_del(splash);
    lv_obj_del(screen);
    ui_init();
    lv_unlock();
    float test = 0;
    bool n = false;
    while (true)
        lv_lock();
        for (int i = 0; i < 8; i++)
            update_values(test, 0, i);
        if(!n)
            test += 0.5f;
        else if (n)
            test -= 0.5f;
        if (test >= 100)
            n = true;
        else if (test <= 0)
            n = false;
        lv_unlock();
        chThdSleepMilliseconds(100);
static void gpt_lvgl_tick(GPTDriver *gptp) {
    (void)gptp;
    lv_tick_inc(1);
static const GPTConfig gptcfg = {
    .frequency = 100000,
    .callback  = gpt_lvgl_tick,
    .cr2       = 0,
    .dier      = 0
void startLVGL()
    palSetPad(GPIOH, 6U);
    lv_display_t *disp = lv_st_ltdc_create_partial(frame_buffer1, frame_buffer_optional, sizeof(frame_buffer_optional), 0);
    chThdCreateStatic(waLV_TIMER_HANDLER, sizeof(waLV_TIMER_HANDLER), NORMALPRIO + 8, LV_TIMER_HANDLER, NULL);
    gptStart(&GPTD1, &gptcfg);
    gptStartContinuous(&GPTD1, 100);
    chThdCreateStatic(waLV_GFX, sizeof(waLV_GFX), NORMALPRIO, LV_GFX, NULL);
https://streamable.com/7ir0nm
The problem is semi resolved.
I’ve changed the location of the draw buffers from sdram to internal SRAM also managed to reduce their size to 1/80th of the full screen and performance is solid 50fps with cpu around 50%
