I have purchased a STM32F769DICO.
This card is supported by lv_micropython ?
Thank you
Thank you
I believe the board is supported by MicroPython itself, however, you would need to add display driver logic to get it working with LVGL, as I don’t think upstream MicroPython ships with display support for this board.
Today micropython is works
~/micropython/board/stm32
make BOARD=STM32F769DISC ... ok
but when i build in
~/lv_micropython/board/stm32
make BOARD=STM32F769DISC ... error
in
~/lv_micropython/
there is only BOARD=STM32F7DISC that works (µC = stm32F746) but is wrong target
Thank you
Yes; as I mentioned, additional logic needs to be added for F769 to work. I believe F429 and F746 are the only supported STM32 boards at the moment.
I think there are two separate issues here.
fails. I would expect it to compile and run, although without display driver so it wouldn’t be able to actually display anything.Hi,
Thank you for your response. There is a video youtube
I suppose that a driver is already exist ? no ?
Thank you
If a driver exists, you just need to compile it with LVGL and Micropython.
You probably also need to add a small wrapper to provide a Micropython API (at least to init/deinit the driver).
That video is using the C driver.
Ok thank you,
The driver C can be convert in micropython ? I have like to try but i don’t know how to start.
Where to find this C driver ?
Thank you
Probably here:
Yes, you need to build it with lv_micropython and create some (thin) micropython API to it.
You can look at the STM32F7DISC micropython port as an example.
The Micropython wrapper is hiding in modrk043fn48h.c. (Look for MP_REGISTER_MODULE
You can find more information here:
https://micropython-usermod.readthedocs.io/en/latest/usermods_05.html
I am also curious about this, unfortunately do not have time right now with other work projects, but running LVGL on a STM32H7 (NXP iMX RT MCUs would be nice but not directly supported by Micropython) with the direct RGB interfaces would be a very interesting combination for me. I would really like supporting up to 1280x800 resolution.
