STM32F769NI, Custom Board with 64Mb SDRAM
Compiler: GNU Arm Embedded Toolchain
Display: 800x480 RGB Controller ST762
Running LVGL without strange visual errors. When I switch through the GUI objects with an encoder the focused elements are getting visually doubled right next to themselves. Tried the same GUI logic in a simulator and everything works fine.
Using the keypad & encoder example from lv_examples as test UI.
LVGL is setup to use DMA2D as GPU. The display flush function uses DMA. Also implemented VSYNC via LTDC line event but disabled it to exclude it as possible source of errors.
Tried RGB and DSI interface (board supports both). Issue exists on both interfaces and 2 different displays.
* @file tft.c
* INCLUDES
#include "lv_conf.h"
#include "lvgl/lvgl.h"
#include <string.h>
#include "bsp/tft.h"
#include "bsp/ili9806e.h"
#include "stm32f7xx_hal.h"
#include "main.h"
* DEFINES
/* DMA Stream parameters definitions. You can modify these parameters to select
a different DMA Stream and/or channel.
But note that only DMA2 Streams are capable of Memory to Memory transfers. */
#define DMA_STREAM DMA2_Stream0
#define DMA_CHANNEL DMA_CHANNEL_0
#define DMA_STREAM_IRQ DMA2_Stream0_IRQn
#define DMA_STREAM_IRQHANDLER DMA2_Stream0_IRQHandler
* TYPEDEFS
* STATIC PROTOTYPES
/*For LittlevGL*/
static void tft_flush_cb(lv_disp_drv_t * drv, const lv_area_t * area, lv_color_t * color_p);
/*LCD*/
static void LCD_Config(void);
void BSP_LCD_Reset(void);
void BSP_LCD_MspInit(void);
/*DMA to flush to frame buffer*/
static void DMA_Config(void);
static void DMA_TransferComplete(DMA_HandleTypeDef *han);
static void DMA_TransferError(DMA_HandleTypeDef *han);
* STATIC VARIABLES
extern LTDC_HandleTypeDef hltdc;
extern DSI_HandleTypeDef hdsi;
__IO uint16_t *FrontBuffer = (__IO uint16_t*)(LCD_FB_START_ADDRESS);
__IO uint16_t *BackBuffer = (__IO uint16_t*) (LCD_FB_START_ADDRESS + 1024 * 1024 * 16); // Only used when VSYNC active
//__IO uint16_t __attribute__((section(".extbss"))) ltdc_fb[TFT_HOR_RES * TFT_VER_RES];
__IO uint16_t *ltdc_fb;
//static lv_color_t __attribute__((section(".extbss"))) lvgl_buffer1[TFT_HOR_RES * TFT_VER_RES];
//static lv_color_t __attribute__((section(".extbss"))) lvgl_buffer2[TFT_HOR_RES * TFT_VER_RES];
static lv_disp_t *tft_disp = NULL;
DMA_HandleTypeDef DmaHandle;
static int32_t x1_flush;
static int32_t y1_flush;
static int32_t x2_flush;
static int32_t y2_fill;
static int32_t y_fill_act;
static const lv_color_t * buf_to_flush;
static volatile uint32_t t_saved = 0;
static volatile bool refr_qry = false;
* MACROS
* GLOBAL FUNCTIONS
* Monitor refresh time
void monitor_cb(lv_disp_drv_t * d, uint32_t t, uint32_t p)
t_saved = t;
* Initialize your display here
void tft_init(void)
LCD_Config();
DMA_Config();
static lv_color_t lvgl_buffer1[LV_HOR_RES_MAX * 48];
static lv_color_t lvgl_buffer2[LV_HOR_RES_MAX * 48];
lv_disp_buf_init(&disp_buf, lvgl_buffer1, lvgl_buffer2,LV_HOR_RES_MAX * 48);
ltdc_fb = FrontBuffer;
lv_disp_drv_init(&disp_drv);
disp_drv.hor_res = 800;
disp_drv.ver_res = 480;
disp_drv.flush_cb = tft_flush_cb;
disp_drv.monitor_cb = monitor_cb;
disp_drv.buffer = &disp_buf;
tft_disp = lv_disp_drv_register(&disp_drv);
* STATIC FUNCTIONS
int32_t x1 = area->x1;
int32_t x2 = area->x2;
int32_t y1 = area->y1;
int32_t y2 = area->y2;
/*Return if the area is out the screen*/
if(x2 < 0) return;
if(y2 < 0) return;
if(x1 > TFT_HOR_RES - 1) return;
if(y1 > TFT_VER_RES - 1) return;
int32_t act_x1 = x1 < 0 ? 0 : x1;
int32_t act_y1 = y1 < 0 ? 0 : y1;
int32_t act_x2 = x2 > TFT_HOR_RES - 1 ? TFT_HOR_RES - 1 : x2;
int32_t act_y2 = y2 > TFT_VER_RES - 1 ? TFT_VER_RES - 1 : y2;
x1_flush = act_x1;
y1_flush = act_y1;
x2_flush = act_x2;
y2_fill = act_y2;
y_fill_act = act_y1;
buf_to_flush = color_p;
SCB_CleanInvalidateDCache();
SCB_InvalidateICache();
/*##-7- Start the DMA transfer using the interrupt mode #*/
/* Configure the source, destination and buffer size DMA fields and Start DMA Stream transfer */
/* Enable All the DMA interrupts */
HAL_StatusTypeDef err;
uint32_t length = (x2_flush - x1_flush + 1);
err = HAL_DMA_Start_IT(&DmaHandle,(uint32_t)buf_to_flush, (uint32_t)<dc_fb[y_fill_act * TFT_HOR_RES + x1_flush],
length);
if(err != HAL_OK)
while(1); /*Halt on error*/
/* Toggle Hardware Reset of the DSI LCD using
* its XRES signal (active low) */
/* Call first MSP Initialize only in case of first initialization
* This will set IP blocks LTDC, DSI and DMA2D
* - out of reset
* - clocked
* - NVIC IRQ related to IP blocks enabled
BSP_LCD_MspInit();
BSP_LCD_Reset();
for(uint32_t i = 0; i < (TFT_HOR_RES * TFT_VER_RES) ; i++)
FrontBuffer[i] = 0;
// BackBuffer[i] = 0;
/* Start DSI */
HAL_Delay(10);
* @brief Configure the DMA controller according to the Stream parameters
* defined in main.h file
* @note This function is used to :
* -1- Enable DMA2 clock
* -2- Select the DMA functional Parameters
* -3- Select the DMA instance to be used for the transfer
* -4- Select Callbacks functions called after Transfer complete and
Transfer error interrupt detection
* -5- Initialize the DMA stream
* -6- Configure NVIC for DMA transfer complete/error interrupts
* @param None
* @retval None
/*## -1- Enable DMA2 clock #################################################*/
__HAL_RCC_DMA2_CLK_ENABLE();
/*##-2- Select the DMA functional Parameters ###############################*/
DmaHandle.Init.Channel = DMA_CHANNEL; /* DMA_CHANNEL_0 */
DmaHandle.Init.Direction = DMA_MEMORY_TO_MEMORY; /* M2M transfer mode */
DmaHandle.Init.PeriphInc = DMA_PINC_ENABLE; /* Peripheral increment mode Enable */
DmaHandle.Init.MemInc = DMA_MINC_ENABLE; /* Memory increment mode Enable */
DmaHandle.Init.PeriphDataAlignment = DMA_PDATAALIGN_WORD; /* Peripheral data alignment : 16bit */
DmaHandle.Init.MemDataAlignment = DMA_MDATAALIGN_WORD; /* memory data alignment : 16bit */
DmaHandle.Init.Mode = DMA_NORMAL; /* Normal DMA mode */
DmaHandle.Init.Priority = DMA_PRIORITY_HIGH; /* priority level : high */
DmaHandle.Init.FIFOMode = DMA_FIFOMODE_ENABLE; /* FIFO mode enabled */
DmaHandle.Init.FIFOThreshold = DMA_FIFO_THRESHOLD_1QUARTERFULL; /* FIFO threshold: 1/4 full */
DmaHandle.Init.MemBurst = DMA_MBURST_SINGLE; /* Memory burst */
DmaHandle.Init.PeriphBurst = DMA_PBURST_SINGLE; /* Peripheral burst */
/*##-3- Select the DMA instance to be used for the transfer : DMA2_Stream0 #*/
DmaHandle.Instance = DMA_STREAM;
/*##-4- Initialize the DMA stream ##########################################*/
if(HAL_DMA_Init(&DmaHandle) != HAL_OK)
while(1);
/*##-5- Select Callbacks functions called after Transfer complete and Transfer error */
HAL_DMA_RegisterCallback(&DmaHandle, HAL_DMA_XFER_CPLT_CB_ID, DMA_TransferComplete);
HAL_DMA_RegisterCallback(&DmaHandle, HAL_DMA_XFER_ERROR_CB_ID, DMA_TransferError);
/*##-6- Configure NVIC for DMA transfer complete/error interrupts ##########*/
HAL_NVIC_SetPriority(DMA_STREAM_IRQ, 5, 0);
HAL_NVIC_EnableIRQ(DMA_STREAM_IRQ);
* @brief DMA conversion complete callback
* @note This function is executed when the transfer complete interrupt
* is generated
* @retval None
y_fill_act ++;
if(y_fill_act > y2_fill) {
//if(lv_disp_flush_is_last(&disp_drv)) refr_qry = true; // For VSYNC,turned off for testing
// else lv_disp_flush_ready(&tft_disp->driver);
} else {
buf_to_flush += x2_flush - x1_flush + 1;
/*##-7- Start the DMA transfer using the interrupt mode ####################*/
if(HAL_DMA_Start_IT(han,(uint32_t)buf_to_flush, (uint32_t)<dc_fb[y_fill_act * TFT_HOR_RES + x1_flush],
length) != HAL_OK)
* @brief DMA conversion error callback
* @note This function is executed when the transfer error interrupt
* is generated during DMA transfer
* @retval None
while(1);
* @brief This function handles DMA Stream interrupt request.
* @param None
* @retval None
void DMA_STREAM_IRQHANDLER(void)
/* Check the interrupt and clear flag */
HAL_DMA_IRQHandler(&DmaHandle);
* @brief Initialize the BSP LCD Msp.
* Do not DMA2D is initialized by LVGL
// HAL_LTDC_ProgramLineEvent(&hltdc, 480); // For VSYNC,turned off for testing
HAL_GPIO_WritePin(LCD_RESET_GPIO_Port, LCD_RESET_Pin, GPIO_PIN_RESET);
HAL_Delay(100);
HAL_GPIO_WritePin(LCD_RESET_GPIO_Port, LCD_RESET_Pin, GPIO_PIN_SET);
void HAL_LTDC_LineEventCallback(LTDC_HandleTypeDef *hltdc) { // For VSYNC,turned off for testing
if(refr_qry) {
refr_qry = 0;
if(ltdc_fb == FrontBuffer) {
ltdc_fb = BackBuffer;
LTDC_LAYER(hltdc, 0)->CFBAR = ((uint32_t)FrontBuffer);
__HAL_LTDC_RELOAD_CONFIG(hltdc);
lv_disp_flush_ready (&disp_drv);
} else {
LTDC_LAYER(hltdc, 0)->CFBAR = ((uint32_t)BackBuffer);
HAL_LTDC_ProgramLineEvent(hltdc, 480);
GIF Animation of the strange behaviour is on giphy because the file exceeds 4Mb see link below:
Shorter example:
![](https://forum.lvgl.io/uploads/default/original/2X/2/2d6bf049a14c8787993c56871f03fe5f4a77b59d.gif)
