STM32F746Disco Issue
Just tried with the data cache enabled, i had disable it since normally never use it, i use a lot of DMA transfers (Usart RX&TX, SPI for external memory access, SPI for WS2812 control, ADC) and want to avoid some issues.
The performance boost is quite significant in this board. In this case the LV_COLOR was set to 32, and using Double Buffer (34 rows), with LV_USE_GPU_STM32_DMA2D enabled.
But the tearing was still noticeable, less than before, but still noticeable in the rectangle tests. But is a no issue, probably the only real workaround would be to have a real “double buffer” in the external RAM for the full Display contents, and switch the buffer in use with the VSYNC signal.
Test Only I Cache D Cache and I Cache
Weighted FPS 128 183
Opa. speed 93 94
Rectangle 193 238
Rectangle + opa 114 107
Rectangle rounded 110 152
Rectangle rounded + opa 75 86
Circle 50 77
Circle + opa 25 45
Border 164 200
Border + opa 151 193
Border rounded 119 162
Border rounded + opa 107 150
Circle border 38 58
Circle border + opa 34 55
Border top 144 194
Border top + opa 139 194
Border left 58 82
Border left + opa 58 82
Border top + left 52 76
Border top + left + opa 41 66
Border left + right 52 76
Border left + right + opa 41 66
Border top + bottom 126 171
Border top + bottom + opa 113 164
Shadow small 26 46
Shadow small + opa 26 46
Shadow small offset 16 26
Shadow small offset + opa 15 26
Shadow large 11 21
Shadow large + opa 10 21
Shadow large offset 9 17
Shadow large offset + opa 9 17
Image RGB 727 761
Image RGB + opa 615 820
Image ARGB 543 800
Image ARGB + opa 592 800
Image chorma keyed 137 309
Image chorma keyed + opa 96 234
Image indexed 65 162
Image indexed + opa 57 137
Image alpha only 88 163
Image alpha only + opa 75 144
Image RGB recolor 82 189
Image RGB recolor + opa 82 188
Image ARGB recolor 87 235
Image ARGB recolor + opa 75 189
Image chorma keyed recolor 96 236
Image chorma keyed recolor + opa 82 189
Image indexed recolor 57 137
Image indexed recolor + opa 51 121
Image RGB rotate 41 138
Image RGB rotate + opa 34 98
Image RGB rotate anti aliased 14 39
Image RGB rotate anti aliased + opa 13 35
Image ARGB rotate 40 123
Image ARGB rotate + opa 36 109
Image ARGB rotate anti aliased 13 36
Image ARGB rotate anti aliased + opa 13 36
Image RGB zoom 46 159
Image RGB zoom + opa 39 122
Image RGB zoom anti aliased 16 43
Image RGB zoom anti aliased + opa 14 39
Image ARGB zoom 46 160
Image ARGB zoom + opa 42 139
Image ARGB zoom anti aliased 15 41
Image ARGB zoom anti aliased + opa 14 41
Text small 28 53
Text small + opa 28 53
Text medium 28 53
Text medium + opa 28 51
Text large 29 54
Text large + opa 28 53
Text small compressed 20 39
Text small compressed + opa 20 38
Text medium compressed 14 29
Text medium compressed + opa 15 29
Text large compressed 7 16
Text large compressed + opa 7 15
Line 59 90
Line + opa 57 87
Arc think 52 72
Arc think + opa 48 70
Arc thick 52 71
Arc thick + opa 46 68
Substr. rectangle 58 82
Substr. rectangle + opa 59 82
Substr. border 100 139
Substr. border + opa 100 140
Substr. shadow 13 22
Substr. shadow + opa 13 22
Substr. image 551 780
Substr. image + opa 607 800
Substr. line 54 84
Substr. line + opa 54 85
Substr. arc 45 64
Substr. arc + opa 45 64
Substr. text 24 46
Substr. text + opa 24 46
