Stm32f401 ili9341 spi dma
Hi all!
STM32F401 SPI DMA bad image picture
STM32F401 Keil
Configuration file for v7.10.1
I want to configure the disp_flush function for SPI DMA
Without using DMA everything just works very slowly.
	ILI9341_Send_Data_DMA(area->x1, area->y1, area->x2, area->y2, (uint8_t *)color_p);
void ILI9341_Send_Data_DMA(uint16_t x_start, uint16_t y_start, uint16_t x_end, uint16_t y_end, uint8_t *p)
	ILI9341_Address_Set(x_start, y_start, x_end, y_end);
	ILI9341_Select();
	HAL_SPI_Transmit_DMA(&ILI9341_SPI_PORT, (uint8_t *)p, (x_end - x_start + 1) * (y_end - y_start + 1) * 2);
	ILI9341_SPI_WAIT_DMA();
void HAL_SPI_TxCpltCallback(SPI_HandleTypeDef *hspi)
  ILI9341_Deselect();
	HAL_SPI_DMAStop(&hspi1);
	lv_disp_flush_ready(&disp_drv);
Problem solved, #define LV_COLOR_16_SWAP must be specified in lv_conf.h settings 1. Thank you!
You solved the problem that troubled me all day, thank you
