lvgl fails to run when code optimisation turned on
I’m running a minimal application than does nothing but display “Hello, World”
The code intialises the LCD SPI interface, but none of the video buffer flushing ever gets called - so prob not my stuff!.
STM32F407
GCC ARM Embedded Toolchain 9-2020-q2-update
ST7735 LCD SPI
What do you experience?
Everything works fine with the optimisation turned off. When I turn on code optimisation (any level) then the application fails to display anything - application loops wating disp_drv->buffer->flushing, but this because memory is trashed and not related to the cause - just a symptom i think.
Obviously debugging is hard when optimisation in on, but one of the first noticeable symptoms is the value of dispBuf.buf2 changing (ie it now points to some random region of memory).
There are other bit of memory changing that shouldnt, so memory is being trashed by something.
I’m trying no nail it down by turning on bits of optimisation and re re run it.
But if anyone else has seen this let me know.
What do you expect?
It to work!
Will update if I get close.
