STM32 with direct double buffering example?
I am using lvgl on a custom STM32H7 board with two frame buffers in SDRAM. I have it working but it is incredibly slow. Can anyone point me towards a repo or example utilizing direct double buffering with an ST chip? Everything displays fine in render mode full but when I switch to direct I have some artifacting. The widgets themselves kind of flicker when they are updated so I don’t think it has to with vsync and that I instead misconfigured it to render into my active buffer.
STM32H743
Double buffering from SDRAM
See my swap function
My lvgl setup and flush functions
void LCD_init(void) {
	lv_display_t * display0  = lv_display_create(WIDTH, HEIGHT);
	//Set up lvgl for double buffering
	lv_display_set_buffers(display0, framebuffer0, framebuffer1, (WIDTH * HEIGHT * 4), LV_DISPLAY_RENDER_MODE_DIRECT);
	lv_display_set_flush_cb(display0, my_flush_cb);
//Buffer flush function for lvgl. Literally just calls swap and ready
static void my_flush_cb(lv_display_t * display, const lv_area_t * area, uint8_t * px_map) {
	FB_Swap((uintptr_t) px_map);
	lv_display_flush_ready(display);
My frame buffer swap function
void FB_Swap(uintptr_t written_buffer) {
	HAL_LTDC_SetAddress(&hltdc, (uint32_t)written_buffer, LTDC_LAYER_1);
	__HAL_LTDC_RELOAD_CONFIG(&hltdc);
Again I’m sure many have done this already I just have not found an example myself with double buffering yet.
@enzobenji , thanks for your message. If you check the LVGL Docs, there are all the steps necessary to configure your device. Regarding double buffering, you need to reserve two regions according to the display resolution on the Link script:
And, there is a thread related to stm32h7:
