I am using a 320*240 screen with ESP32 S3 - ST7789 Driver. When the screen is upright, the tearing problem appears very little, but it is not completely gone. I would like to get information about this issue?
* 8080 BUS Initialize
static lv_disp_draw_buf_t disp_buf; // contains internal graphic buffer(s) called draw buffer(s)
static lv_disp_drv_t disp_drv; // contains callback functions
ESP_LOGI(TAG, “Initialize Intel 8080 bus”);
esp_lcd_i80_bus_handle_t i80_bus = NULL;
esp_lcd_i80_bus_config_t bus_config = {
.clk_src = SOC_MOD_CLK_PLL_D2,
.dc_gpio_num = PIN_NUM_DC,
.wr_gpio_num = PIN_NUM_PCLK,
.data_gpio_nums = {
PIN_NUM_DATA0,
PIN_NUM_DATA1,
PIN_NUM_DATA2,
PIN_NUM_DATA3,
PIN_NUM_DATA4,
PIN_NUM_DATA5,
PIN_NUM_DATA6,
PIN_NUM_DATA7,
.bus_width = CONFIG_EXAMPLE_LCD_I80_BUS_WIDTH,
.max_transfer_bytes = LCD_H_RES * LCD_V_RES * sizeof(uint16_t),
.psram_trans_align = 64,
.sram_trans_align = 4,
ESP_ERROR_CHECK(esp_lcd_new_i80_bus(&bus_config, &i80_bus));
esp_lcd_panel_io_handle_t io_handle = NULL;
esp_lcd_panel_io_i80_config_t io_config = {
.cs_gpio_num = PIN_NUM_CS,
.pclk_hz = LCD_PIXEL_CLOCK_HZ,
.trans_queue_depth = 10,
.dc_levels = {
.dc_idle_level = 0,
.dc_cmd_level = 0,
.dc_dummy_level = 0,
.dc_data_level = 1,
.flags = {
.swap_color_bytes = !LV_COLOR_16_SWAP, // Swap can be done in LvGL (default) or DMA
.on_color_trans_done = notify_lvgl_flush_ready,
.user_ctx = &disp_drv,
.lcd_cmd_bits = LCD_CMD_BITS,
.lcd_param_bits = LCD_PARAM_BITS,
ESP_ERROR_CHECK(esp_lcd_new_panel_io_i80(i80_bus, &io_config, &io_handle));
esp_lcd_panel_handle_t panel_handle = NULL;
ESP_LOGI(TAG, "Install LCD driver of st7789");
esp_lcd_panel_dev_config_t panel_config = {
.reset_gpio_num = PIN_NUM_RST,
.rgb_endian = LCD_RGB_ENDIAN_BGR,
.bits_per_pixel = 16,
ESP_ERROR_CHECK(esp_lcd_new_panel_st7789(io_handle, &panel_config, &panel_handle));
esp_lcd_panel_reset(panel_handle);
esp_lcd_panel_init(panel_handle);
// Set inversion, x/y coordinate order, x/y mirror according to your LCD module spec
// the gap is LCD panel specific, even panels with the same driver IC, can have different gap value
esp_lcd_panel_invert_color(panel_handle, true);
esp_lcd_panel_set_gap(panel_handle, 0, 0);
// user can flush pre-defined pattern to the screen before we turn on the screen or backlight
ESP_ERROR_CHECK(esp_lcd_panel_disp_on_off(panel_handle, true));
/*esp_lcd_panel_swap_xy(panel_handle, true);
esp_lcd_panel_mirror(panel_handle, true,true);*/
ESP_LOGI(TAG, "Initialize LVGL library");
//lv_disp_set_rotation(disp, LV_DISP_ROT_90);
// alloc draw buffers used by LVGL
// it's recommended to choose the size of the draw buffer(s) to be at least 1/10 screen sized
lv_color_t *buf1 = NULL;
lv_color_t *buf2 = NULL;
// static lv_color_t buf1[655 * 100];
// static lv_color_t buf2[655 * 100];
buf1 = heap_caps_malloc(LCD_H_RES * LCD_V_RES * sizeof(lv_color_t), MALLOC_CAP_DMA | MALLOC_CAP_INTERNAL);
//assert(buf1);
buf2 = heap_caps_malloc(LCD_H_RES * LCD_V_RES * sizeof(lv_color_t), MALLOC_CAP_DMA | MALLOC_CAP_INTERNAL);
assert(buf2);
ESP_LOGI(TAG, “buf1@%p, buf2@%p”, buf1, buf2);
// initialize LVGL draw buffers
lv_disp_draw_buf_init(&disp_buf, buf1, NULL,LCD_H_RES * LCD_V_RES502);
ESP_LOGI(TAG, "Register display driver to LVGL");
lv_disp_drv_init(&disp_drv);
disp_drv.hor_res = LCD_H_RES;
disp_drv.ver_res = LCD_V_RES;
disp_drv.flush_cb = lvgl_flush_cb;
disp_drv.user_data = panel_handle;
disp_drv.full_refresh =1;
disp = lv_disp_drv_register(&disp_drv);
ESP_LOGI(TAG, "Install LVGL tick timer");
// Tick interface for LVGL (using esp_timer to generate 2ms periodic event)
const esp_timer_create_args_t lvgl_tick_timer_args = {
.callback = &increase_lvgl_tick,
.name = "lvgl_tick"
esp_timer_handle_t lvgl_tick_timer = NULL;
ESP_ERROR_CHECK(esp_timer_create(&lvgl_tick_timer_args, &lvgl_tick_timer));
ESP_ERROR_CHECK(esp_timer_start_periodic(lvgl_tick_timer, LVGL_TICK_PERIOD_MS * 1000));
