I’m trying to get software rotation to work on LVGL but it’s giving me some issues. I’m hoping there’s some point I’m missing to get it to work properly.
I’ve started from the ESP-IDF example app which works fine in the default landscape mode (except some weird black line that appears there). The OLED controlled (SSD1306) doesn’t support rotation in hardware.
ESP-32 + I2C SSD1306 + 0.91" OLED display (32x128)
8.2.0
The display is encased in a device that will hold the display in portrait mode so I need the icons and text to be rotated.
I’ve enabled software rotation in the display driver structure. I’ve tried 90 degree rotation which shows up as the below image. I’ve also tried 180 degree rotation, but that didn’t seem to do anything.
Based on the ESP-IDF example, linked above, I added the following lines
disp_drv.sw_rotate = 1;
//disp_drv.rotated = LV_DISP_ROT_180;
disp_drv.rotated = LV_DISP_ROT_90;
In addition, I’ve change the example to include 3 labels aligned to top, middle and bottom:
lv_obj_t *label = lv_label_create(scr);
lv_label_set_long_mode(label, LV_LABEL_LONG_SCROLL_CIRCULAR);
lv_label_set_text(label, "Hello Espressif, Hello LVGL.");
lv_obj_set_width(label, 150);
lv_obj_align(label, LV_ALIGN_TOP_LEFT, 0, 0);
lv_obj_align(label, LV_ALIGN_LEFT_MID, 0, 0);
lv_obj_align(label, LV_ALIGN_BOTTOM_LEFT, 0, 0);
This is how it’s displayed without rotation:
(Not sure what the deal with the black line there)
With 90 software rotation:
It seems that it does align the text correctly but it’s not rotated and there’s the noise between the labels.
It’s my understanding that I don’t need to modify any of the driver callbacks when enabling software rotation so what am I missing?
Thanks in advance!
