Hello all!
I’m trying to upload a screen (created with Squareline) to the Raspberry Pi Pico and show it on the GC9A01 display. After the upload the display shows only garbage.
RP2040 with Arduino framework on PlatformIO
I want to show the generated screen on the display.
Code of Platformio.ini
[env:pico]
platform = raspberrypi
board = pico
framework = arduino
monitor_port = COM4
monitor_speed = 115200
lib_deps =
lvgl/lvgl@^8.3.6
https://github.com/Bodmer/TFT_eSPI
build_flags =
; TFT_eSPI library setting here (no need to edit library files):
-D USER_SETUP_LOADED=1 ; Set this settings as valid
-D GC9A01_DRIVER=1 ; Select ILI9163 driver
-D TFT_WIDTH=240 ; Set TFT size
-D TFT_HEIGHT=240
-D TFT_MOSI=7
-D TFT_SCLK=6
-D TFT_CS=5
-D TFT_DC=4 ; Data/Comand pin
-D TFT_RST=3 ; Reset pin
-D LOAD_GLCD=1 ; Load Fonts
-D SPI_FREQUENCY=27000000 ; Set SPI frequency
lib_ignore = Portenta_lvgl
main.cpp
#include <lvgl.h>
#include <TFT_eSPI.h>
#include <ui.h>
/*Don't forget to set Sketchbook location in File/Preferencesto the path of your UI project (the parent foder of this INO file)*/
/*Change to your screen resolution*/
static const uint16_t screenWidth = 240;
static const uint16_t screenHeight = 240;
static lv_color_t buf[ screenWidth * screenHeight / 10 ];
TFT_eSPI tft = TFT_eSPI(screenWidth, screenHeight); /* TFT instance */
#if LV_USE_LOG != 0
/* Serial debugging */
void my_print(const char * buf)
Serial.printf(buf);
Serial.flush();
/* Display flushing */
void my_disp_flush( lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p )
uint32_t w = ( area->x2 - area->x1 + 1 );
uint32_t h = ( area->y2 - area->y1 + 1 );
tft.startWrite();
tft.setAddrWindow( area->x1, area->y1, w, h );
tft.pushColors( ( uint16_t * )&color_p->full, w * h, true );
tft.endWrite();
lv_disp_flush_ready( disp );
/*Read the touchpad*/
void my_touchpad_read( lv_indev_drv_t * indev_driver, lv_indev_data_t * data )
uint16_t touchX = 0, touchY = 0;
bool touched = false;//tft.getTouch( &touchX, &touchY, 600 );
if( !touched )
/*Set the coordinates*/
data->point.x = touchX;
data->point.y = touchY;
Serial.print( "Data x " );
Serial.println( touchX );
Serial.print( "Data y " );
Serial.println( touchY );
void setup()
Serial.begin( 115200 ); /* prepare for possible serial debug */
LVGL_Arduino += String('V') + lv_version_major() + "." + lv_version_minor() + "." + lv_version_patch();
Serial.println( LVGL_Arduino );
Serial.println( "I am LVGL_Arduino" );
#if LV_USE_LOG != 0
lv_log_register_print_cb( my_print ); /* register print function for debugging */
tft.begin(); /* TFT init */
tft.setRotation( 3 ); /* Landscape orientation, flipped */
lv_disp_draw_buf_init( &draw_buf, buf, NULL, screenWidth * screenHeight / 10 );
/*Initialize the display*/
/*Change the following line to your display resolution*/
lv_disp_drv_register( &disp_drv );
lv_indev_drv_init( &indev_drv );
lv_indev_drv_register( &indev_drv );
ui_init();
void loop()
delay(5);
Display shows me only garbage after the upload.
I’m a total noob with lvgl and hope someone can help me
to show the screen correct on the display.
Thanks a lot and best regards
