Simple question :
I have created an Arduino project with SquareLine_Studio.
Resolution 480 X 320
Rotation 0 deg
Shape rectangle
Color depth 32 bit
Lvgl version 8.3.4
After placing widgets ( numeric keyboard and text area ) I made everything to export the project : ui libs …
At the end the display show what I expected. Except flipped touch in X.
Ui.ino file show : tft.setRotation( 3 ); /* Landscape orientation, flipped */
Then I suspect this . Expected rotation must be 1 and not 3
I tried to change export rotation parameter with 0 degree and 180 degree
for both the result is the same ; tft.setRotation( 3 ); /* Landscape orientation, flipped */
The other way to exit from this problem is to flip something in function my_touchpad_read
Any idea ?
Hardware Pi pico, tft spi 480X320 v2.0
Soft: Platformio
ui.ino renamed main.cpp
config file ** [env:rpipico]
platform = GitHub - maxgerhardt/platform-raspberrypi: Raspberry Pi: development platform for PlatformIO
board = pico
framework = arduino
board_build.core = earlephilhower
;lib_deps = “” (All in library folder)
