Hi,I encountered a problem.When using the example code, there are split stripes in the horizontal direction,normal vertical movement
Xilinx mpsoc
8.3.3
Is there any way to remove the cut stripes during horizontal movement
/*Create a container with ROW flex direction*/
lv_obj_t * cont_row = lv_obj_create(cur_scr_act);
lv_obj_set_size(cont_row, 300, 200);
lv_obj_align(cont_row, LV_ALIGN_TOP_MID, 0, 5);
lv_obj_set_flex_flow(cont_row, LV_FLEX_FLOW_ROW);
/*Create a container with COLUMN flex direction*/
lv_obj_t * cont_col = lv_obj_create(cur_scr_act);
lv_obj_set_size(cont_col, 200, 150);
lv_obj_align_to(cont_col, cont_row, LV_ALIGN_OUT_BOTTOM_MID, 0, 5);
lv_obj_set_flex_flow(cont_col, LV_FLEX_FLOW_COLUMN);
uint32_t i;
for(i = 0; i < 10; i++) {
lv_obj_t * obj;
lv_obj_t * label;
/*Add items to the row*/
obj= lv_btn_create(cont_row);
lv_obj_set_style_bg_color(obj,lv_color_make(64,64,64),0);
lv_obj_set_size(obj, 100, LV_PCT(100));
label = lv_label_create(obj);
lv_label_set_text_fmt(label, "Item: %u", i);
lv_obj_center(label);
/*Add items to the column*/
obj = lv_btn_create(cont_col);
lv_obj_set_size(obj, LV_PCT(100), LV_SIZE_CONTENT);
lv_label_set_text_fmt(label, "Item: %d", i);
Normal
@embeddedt @kisvegabor
Can give me some advice? Thank in advance
