Spinbox number input issue
2 words showing with 1 number key press action in widget spinbox
Windows
V9
1 words showing with 1 nubmer key press action in widget spinbox
Delete lv_textarea_add_char(obj, c);
in lv_spinbox.c line:395
I think it can be reproduced in the document page.
Spinbox (lv_spinbox) — LVGL documentation
1
I think this issue is because spinbox is inherited from textarea widget.
In the initialize stage spinbox will have a baseclass like:.base_class = &lv_textarea_class,
And the spinbox’s defalut event cb will call : res = lv_obj_event_base(MY_CLASS, e); in lv_spinbox.c line:303
Which leads to the textarea’s default event cb to call lv_textarea_add_char() firstly.
Then the pinbox’s defalut event cb will call lv_textarea_add_char() again.
I want to have one word only changing in each press action. But I also need some features in both spinbox and textarea so I can not change the derivation or block the event passing in these two widgets.
I don’t want to change the LVGL folder’s files at all.My idea is to replace the whole default event cb for spinbox but there a lots of internal member.
Is there any idea to fix this?
BR/Kuan
