I wrote my own curve control referring to lv_chart. When the cursor moves over, there will be smear. Other controls will not.
Can you give some suggestions?
STM32F429
V7.7.0
When the cursor moves over, there will be normal.
lv_obj_set_click(m_curveObj,false);
or lv_obj_set_click(m_curveObj,true); do not work.
NA
Can you send a code sample, please?
I have send a message to you
It seems to depend on other files.
Can you create a self-contained code sample that will run in the PC simulator and send that?
“Other files” contains an empty class.
On VS2017, I can’t do a mixed compilation of C and C++.
I tried to reproduce this problem in the simulator in C mode, but a new problem appeared: when the mouse moves into the control area, an exception will occur.
CurveCtrl.h (253 Bytes) CurveCtrl.c (7.9 KB)
In file lv_demo_widgets.c ,add test curve function
show cursor
Do you know what went wrong?
