We’re using LVGL v8.1.0. There is an arabic word رائع ,unicode array of the word is 0x631 0x627 0x626 0x639. In LVGL, the word seems to display uncorrectly, as follow:
After some debugging in source code, we found that in lv_txt_ap.c, the 4th item in the array ap_chars_map may cause the problem. After we change the 4th item value from:
{4, 0xFE8A, 1, 2, -1, {1, 0}}, // ئ
to:
{4, 0xFE8A, 1, 2, -1, {1, 1}}, // ئ
then LVGL can display the correct form of the word, as follow:
But we’re not familiar with arabic language ourselves, and the change of the ap_chars_map may cause other errors if we’re not correct about the change.
Anyone konws whether we’re doing it right or not?
Thank you!
