I am using platformio in vscode to compile for a ESP32-8048S043. I found example code at GitHub - pixelwave/Sunton-ESP32-8048S043: First test with Sunton ESP32-8048S043 + Squareline UI + LVGL + Arduino GFX. I downloaded it and it runs fine. I wanted to use a larger font so I generated a 50 px freesans font. I moved the generated c code to lib/lvgl/src/font. I didn’t know if this belonged in the PlatformIO forum or here, but I decided I’d start here. For some reason, the library dependency finder is using a different library rather than using compiling the files in the lib directory. I add a dep_libs directive to point to file://lib/lvgl but it seems to be ignoring it. Here’s the layout uploaded:
What ever is in that file.
I’m trying to add a new font.
This isn’t about my code specifically, it’s more of a structural issue. Once I get the library to compile I think I will be able to continue.
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ deep+, Compatibility ~ soft
Found 35 compatible libraries
Scanning dependencies...
Dependency Graph
|-- GFX Library for Arduino @ 1.3.0
|-- TAMC_GT911 @ 1.0.2
|-- SPI @ 2.0.0
|-- Wire @ 2.0.0
Building in release mode
Compiling .pio/build/esp32s3box/src/main.cpp.o
Compiling .pio/build/esp32s3box/src/screens/ui_Screen1.c.o
Compiling .pio/build/esp32s3box/src/screens/ui_Screen2.c.o
Compiling .pio/build/esp32s3box/src/ui.c.o
src/screens/ui_Screen2.c: In function 'ui_Screen2_screen_init':
src/screens/ui_Screen2.c:25:40: error: 'freesans_50' undeclared (first use in this function)
Sure it’s not declared 'cause the compile is ignoring the files in the lib directory. I guess I’ve missed some include or didn’t add a line to an existing include but I don’t quite know where to put it.
Thanks,
Jim
