I’m new to LVGL, and am trying to run the slider example. I am able to display the slider and get touch inputs, but it takes about 4 seconds for the slider to respond to a touch input.
The performance monitor indicates 33 FPS and 2-4% CPU when no touch is present, jumping to 100% momentarily when the screen is touched off of the slider. When the slider is touched, everything appears to freeze for about 4 seconds, then the slider jumps to the touch location. After the touch is released the performance monitor resumes updating.
BlackPill F411CE, Adafruit ILI9341 2.8" Touchscreen, and PlatformIO with Arduino framework.
I want to correct the issue that is causing the freeze up / slow response.
Changing tick period and main loop delay, display refresh period, none of which had any effect at all.
#include <lvgl.h>
#include <TFT_eSPI.h>
#include "TouchScreen.h"
#define LVGL_TICK_PERIOD 60
// #define USE_LV_LOG 1 /*Enable/disable the log module*/
#define YP PB1 // must be an analog pin, use "An" notation!
#define XM PB0 // must be an analog pin, use "An" notation!
#define YM PB15 // can be a digital pin
#define XP PB14 // can be a digital pin
#define TS_MINX 130
#define TS_MINY 100
#define TS_MAXX 910
#define TS_MAXY 910
#define TS_MAXZ 300
#define TS_MINZ 1200
//Ticker tick; /* timer for interrupt handler */
lv_obj_t *slider_label;
int screenWidth = 320;
int screenHeight = 240;
#if USE_LV_LOG != 0
/* Serial debugging */
void my_print(lv_log_level_t level, const char *file, uint32_t line, const char *dsc)
Serial.printf("%[email protected]%d->%s\r\n", file, line, dsc);
delay(100);
TouchScreen touch = TouchScreen(XP, YP, XM, YM, 330);
/* Display flushing */
uint16_t c;
tft.startWrite(); /* Start new TFT transaction */
tft.setAddrWindow(area->x1, area->y1, (area->x2 - area->x1 + 1), (area->y2 - area->y1 + 1)); /* set the working window */
for (int y = area->y1; y <= area->y2; y++)
for (int x = area->x1; x <= area->x2; x++)
c = color_p->full;
tft.writeColor(c, 1);
color_p++;
tft.endWrite(); /* terminate TFT transaction */
lv_disp_flush_ready(disp); /* tell lvgl that flushing is done */
bool my_touchpad_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data)
uint16_t touchX;
uint16_t touchY;
uint16_t x = 0;
uint16_t y = 0;
bool touched = false;
TSPoint p = touch.getPoint();
if (p.z > 0)
x = map(p.y, TS_MINX, TS_MAXX, 0, 320);
y = map(p.x, TS_MAXY, TS_MINY, 0, 240);
p.y = y;
p.x = x;
touched = true;
touchX = p.x;
touchY = p.y;
if (!touched)
return false;
if (touchX > screenWidth || touchY > screenHeight)
Serial.println("x or y outside of expected parameters..");
Serial.print("y:");
Serial.print(touchX);
Serial.print(" x:");
Serial.print(touchY);
data->state = touched ? LV_INDEV_STATE_PR : LV_INDEV_STATE_REL;
/*Save the state and save the pressed coordinate*/
//if(data->state == LV_INDEV_STATE_PR) touchpad_get_xy(&last_x, &last_y);
/*Set the coordinates (if released use the last pressed coordinates)*/
data->point.x = touchX;
data->point.y = touchY;
return false; /*Return `false` because we are not buffering and no more data to read*/
/* Callbacks */
void printEvent(String Event, lv_event_t event)
Serial.print(Event);
printf(" ");
switch (event)
case LV_EVENT_PRESSED:
printf("Pressed\n");
break;
case LV_EVENT_SHORT_CLICKED:
printf("Short clicked\n");
break;
case LV_EVENT_CLICKED:
printf("Clicked\n");
break;
case LV_EVENT_LONG_PRESSED:
printf("Long press\n");
break;
case LV_EVENT_LONG_PRESSED_REPEAT:
printf("Long press repeat\n");
break;
case LV_EVENT_RELEASED:
printf("Released\n");
break;
void slider_event_cb(lv_obj_t *slider, lv_event_t event)
printEvent("Slider", event);
if (event == LV_EVENT_VALUE_CHANGED)
static char buf[4]; /* max 3 bytes for number plus 1 null terminating byte */
snprintf(buf, 4, "%u", lv_slider_get_value(slider));
lv_label_set_text(slider_label, buf); /*Refresh the text*/
void setup()
Serial.println("Serial working...");
#if USE_LV_LOG != 0
lv_log_register_print_cb(my_print); /* register print function for debugging */
tft.begin(); /* TFT init */
tft.setRotation(1);
lv_disp_buf_init(&disp_buf, buf, NULL, LV_HOR_RES_MAX * 10);
/*Initialize the display*/
lv_disp_drv_t disp_drv;
lv_disp_drv_init(&disp_drv);
disp_drv.buffer = &disp_buf;
/*Initialize the input device driver*/
lv_indev_drv_t indev_drv;
lv_indev_drv_init(&indev_drv); /*Descriptor of a input device driver*/
indev_drv.type = LV_INDEV_TYPE_POINTER; /*Touch pad is a pointer-like device*/
indev_drv.read_cb = my_touchpad_read; /*Set your driver function*/
lv_indev_drv_register(&indev_drv); /*Finally register the driver*/
//Set the theme..
lv_theme_t *th = lv_theme_material_init(LV_THEME_DEFAULT_COLOR_PRIMARY, LV_THEME_DEFAULT_COLOR_SECONDARY, LV_THEME_DEFAULT_FLAG, LV_THEME_DEFAULT_FONT_SMALL, LV_THEME_DEFAULT_FONT_NORMAL, LV_THEME_DEFAULT_FONT_SUBTITLE, LV_THEME_DEFAULT_FONT_TITLE);
lv_theme_set_act(th);
lv_obj_t *scr = lv_cont_create(NULL, NULL);
lv_disp_load_scr(scr);
//lv_obj_t * tv = lv_tabview_create(scr, NULL);
//lv_obj_set_size(tv, lv_disp_get_hor_res(NULL), lv_disp_get_ver_res(NULL));
/* Create simple label */
lv_obj_t *label = lv_label_create(lv_scr_act(), NULL);
lv_label_set_text(label, "Hello Slider! (V7.0)");
lv_obj_align(label, NULL, LV_ALIGN_CENTER, 0, -50);
/* Create a slider in the center of the display */
lv_obj_t *slider = lv_slider_create(lv_scr_act(), NULL);
lv_obj_set_width(slider, screenWidth - 50); /*Set the width*/
lv_obj_set_height(slider, 50);
lv_obj_align(slider, NULL, LV_ALIGN_CENTER, 12, 0); /*Align to the center of the parent (screen)*/
lv_obj_set_event_cb(slider, slider_event_cb); /*Assign an event function*/
/* Create a label below the slider */
slider_label = lv_label_create(lv_scr_act(), NULL);
lv_label_set_text(slider_label, "0");
lv_obj_set_auto_realign(slider, true);
lv_obj_align(slider_label, slider, LV_ALIGN_OUT_BOTTOM_MID, 0, 10);
void loop()
delay(20);
lv_conf.h
* @file lv_conf.h
* COPY THIS FILE AS `lv_conf.h` NEXT TO the `lvgl` FOLDER
#ifndef LV_CONF_H
#define LV_CONF_H
/* clang-format off */
#include <stdint.h>
Graphical settings
/* Maximal horizontal and vertical resolution to support by the library.*/
#define LV_HOR_RES_MAX (320)
#define LV_VER_RES_MAX (240)
/* Color depth:
* - 1: 1 byte per pixel
* - 8: RGB233
* - 16: RGB565
* - 32: ARGB8888
#define LV_COLOR_DEPTH 16
/* Swap the 2 bytes of RGB565 color.
* Useful if the display has a 8 bit interface (e.g. SPI)*/
#define LV_COLOR_16_SWAP 0
/* 1: Enable screen transparency.
* Useful for OSD or other overlapping GUIs.
* Requires `LV_COLOR_DEPTH = 32` colors and the screen's style should be modified: `style.body.opa = ...`*/
#define LV_COLOR_SCREEN_TRANSP 0
/*Images pixels with this color will not be drawn (with chroma keying)*/
#define LV_COLOR_TRANSP LV_COLOR_LIME /*LV_COLOR_LIME: pure green*/
/* Enable anti-aliasing (lines, and radiuses will be smoothed) */
#define LV_ANTIALIAS 1
/* Default display refresh period.
* Can be changed in the display driver (`lv_disp_drv_t`).*/
#define LV_DISP_DEF_REFR_PERIOD 60 /*[ms]*/
/* Dot Per Inch: used to initialize default sizes.
* E.g. a button with width = LV_DPI / 2 -> half inch wide
* (Not so important, you can adjust it to modify default sizes and spaces)*/
#define LV_DPI 130 /*[px]*/
/* The the real width of the display changes some default values:
* default object sizes, layout of examples, etc.
* According to the width of the display (hor. res. / dpi)
* the displays fall in 4 categories.
* The 4th is extra large which has no upper limit so not listed here
* The upper limit of the categories are set below in 0.1 inch unit.
#define LV_DISP_SMALL_LIMIT 30
#define LV_DISP_MEDIUM_LIMIT 50
#define LV_DISP_LARGE_LIMIT 70
/* Type of coordinates. Should be `int16_t` (or `int32_t` for extreme cases) */
typedef int16_t lv_coord_t;
Memory manager settings
/* LittelvGL's internal memory manager's settings.
* The graphical objects and other related data are stored here. */
/* 1: use custom malloc/free, 0: use the built-in `lv_mem_alloc` and `lv_mem_free` */
#define LV_MEM_CUSTOM 0
#if LV_MEM_CUSTOM == 0
/* Size of the memory used by `lv_mem_alloc` in bytes (>= 2kB)*/
# define LV_MEM_SIZE (32U * 1024U)
/* Complier prefix for a big array declaration */
# define LV_MEM_ATTR
/* Set an address for the memory pool instead of allocating it as an array.
* Can be in external SRAM too. */
# define LV_MEM_ADR 0
/* Automatically defrag. on free. Defrag. means joining the adjacent free cells. */
# define LV_MEM_AUTO_DEFRAG 1
#else /*LV_MEM_CUSTOM*/
# define LV_MEM_CUSTOM_INCLUDE <stdlib.h> /*Header for the dynamic memory function*/
# define LV_MEM_CUSTOM_ALLOC malloc /*Wrapper to malloc*/
# define LV_MEM_CUSTOM_FREE free /*Wrapper to free*/
#endif /*LV_MEM_CUSTOM*/
/* Garbage Collector settings
* Used if lvgl is binded to higher level language and the memory is managed by that language */
#define LV_ENABLE_GC 0
#if LV_ENABLE_GC != 0
# define LV_GC_INCLUDE "gc.h" /*Include Garbage Collector related things*/
# define LV_MEM_CUSTOM_REALLOC your_realloc /*Wrapper to realloc*/
# define LV_MEM_CUSTOM_GET_SIZE your_mem_get_size /*Wrapper to lv_mem_get_size*/
#endif /* LV_ENABLE_GC */
Input device settings
/* Input device default settings.
* Can be changed in the Input device driver (`lv_indev_drv_t`)*/
/* Input device read period in milliseconds */
#define LV_INDEV_DEF_READ_PERIOD 30
/* Drag threshold in pixels */
#define LV_INDEV_DEF_DRAG_LIMIT 10
/* Drag throw slow-down in [%]. Greater value -> faster slow-down */
#define LV_INDEV_DEF_DRAG_THROW 10
/* Long press time in milliseconds.
* Time to send `LV_EVENT_LONG_PRESSSED`) */
#define LV_INDEV_DEF_LONG_PRESS_TIME 400
/* Repeated trigger period in long press [ms]
* Time between `LV_EVENT_LONG_PRESSED_REPEAT */
#define LV_INDEV_DEF_LONG_PRESS_REP_TIME 100
/* Gesture threshold in pixels */
#define LV_INDEV_DEF_GESTURE_LIMIT 50
/* Gesture min velocity at release before swipe (pixels)*/
#define LV_INDEV_DEF_GESTURE_MIN_VELOCITY 3
* Feature usage
/*1: Enable the Animations */
#define LV_USE_ANIMATION 1
#if LV_USE_ANIMATION
/*Declare the type of the user data of animations (can be e.g. `void *`, `int`, `struct`)*/
typedef void * lv_anim_user_data_t;
/* 1: Enable shadow drawing*/
#define LV_USE_SHADOW 1
#if LV_USE_SHADOW
/* Allow buffering some shadow calculation
* LV_SHADOW_CACHE_SIZE is the max. shadow size to buffer,
* where shadow size is `shadow_width + radius`
* Caching has LV_SHADOW_CACHE_SIZE^2 RAM cost*/
#define LV_SHADOW_CACHE_SIZE 0
/* 1: Use other blend modes than normal (`LV_BLEND_MODE_...`)*/
#define LV_USE_BLEND_MODES 0
/* 1: Use the `opa_scale` style property to set the opacity of an object and its children at once*/
#define LV_USE_OPA_SCALE 1
/* 1: Use image zoom and rotation*/
#define LV_USE_IMG_TRANSFORM 1
/* 1: Enable object groups (for keyboard/encoder navigation) */
#define LV_USE_GROUP 1
#if LV_USE_GROUP
typedef void * lv_group_user_data_t;
#endif /*LV_USE_GROUP*/
/* 1: Enable GPU interface*/
#define LV_USE_GPU 1 /*Only enables `gpu_fill_cb` and `gpu_blend_cb` in the disp. drv- */
#define LV_USE_GPU_STM32_DMA2D 0
/* 1: Enable file system (might be required for images */
#define LV_USE_FILESYSTEM 1
#if LV_USE_FILESYSTEM
/*Declare the type of the user data of file system drivers (can be e.g. `void *`, `int`, `struct`)*/
typedef void * lv_fs_drv_user_data_t;
/*1: Add a `user_data` to drivers and objects*/
#define LV_USE_USER_DATA 0
/*1: Show CPU usage and FPS count in the right bottom corner*/
#define LV_USE_PERF_MONITOR 1
/*1: Use the functions and types from the older API if possible */
#define LV_USE_API_EXTENSION_V6 1
* Image decoder and cache
/* 1: Enable indexed (palette) images */
#define LV_IMG_CF_INDEXED 1
/* 1: Enable alpha indexed images */
#define LV_IMG_CF_ALPHA 1
/* Default image cache size. Image caching keeps the images opened.
* If only the built-in image formats are used there is no real advantage of caching.
* (I.e. no new image decoder is added)
* With complex image decoders (e.g. PNG or JPG) caching can save the continuous open/decode of images.
* However the opened images might consume additional RAM.
* LV_IMG_CACHE_DEF_SIZE must be >= 1 */
#define LV_IMG_CACHE_DEF_SIZE 1
/*Declare the type of the user data of image decoder (can be e.g. `void *`, `int`, `struct`)*/
typedef void * lv_img_decoder_user_data_t;
* Compiler settings
/* Define a custom attribute to `lv_tick_inc` function */
#define LV_ATTRIBUTE_TICK_INC
/* Define a custom attribute to `lv_task_handler` function */
#define LV_ATTRIBUTE_TASK_HANDLER
/* Define a custom attribute to `lv_disp_flush_ready` function */
/* With size optimization (-Os) the compiler might not align data to
* 4 or 8 byte boundary. This alignment will be explicitly applied where needed.
* E.g. __attribute__((aligned(4))) */
#define LV_ATTRIBUTE_MEM_ALIGN
/* Attribute to mark large constant arrays for example
* font's bitmaps */
/* Prefix performance critical functions to place them into a faster memory (e.g RAM)
* Uses 15-20 kB extra memory */
#define LV_ATTRIBUTE_FAST_MEM
/* Export integer constant to binding.
* This macro is used with constants in the form of LV_<CONST> that
* should also appear on lvgl binding API such as Micropython
* The default value just prevents a GCC warning.
#define LV_EXPORT_CONST_INT(int_value) struct _silence_gcc_warning
* HAL settings
/* 1: use a custom tick source.
* It removes the need to manually update the tick with `lv_tick_inc`) */
#define LV_TICK_CUSTOM 1
#if LV_TICK_CUSTOM == 1
#define LV_TICK_CUSTOM_INCLUDE "Arduino.h" /*Header for the sys time function*/
#define LV_TICK_CUSTOM_SYS_TIME_EXPR (millis()) /*Expression evaluating to current systime in ms*/
#endif /*LV_TICK_CUSTOM*/
typedef void * lv_disp_drv_user_data_t; /*Type of user data in the display driver*/
typedef void * lv_indev_drv_user_data_t; /*Type of user data in the input device driver*/
* Log settings
/*1: Enable the log module*/
#define LV_USE_LOG 1
#if LV_USE_LOG
/* How important log should be added:
* LV_LOG_LEVEL_TRACE A lot of logs to give detailed information
* LV_LOG_LEVEL_INFO Log important events
* LV_LOG_LEVEL_WARN Log if something unwanted happened but didn't cause a problem
* LV_LOG_LEVEL_ERROR Only critical issue, when the system may fail
* LV_LOG_LEVEL_NONE Do not log anything
# define LV_LOG_LEVEL LV_LOG_LEVEL_INFO
/* 1: Print the log with 'printf';
* 0: user need to register a callback with `lv_log_register_print_cb`*/
# define LV_LOG_PRINTF 1
#endif /*LV_USE_LOG*/
* Debug settings
/* If Debug is enabled LittelvGL validates the parameters of the functions.
* If an invalid parameter is found an error log message is printed and
* the MCU halts at the error. (`LV_USE_LOG` should be enabled)
* If you are debugging the MCU you can pause
* the debugger to see exactly where the issue is.
* The behavior of asserts can be overwritten by redefining them here.
* E.g. #define LV_ASSERT_MEM(p) <my_assert_code>
#define LV_USE_DEBUG 0
#if LV_USE_DEBUG
/*Check if the parameter is NULL. (Quite fast) */
#define LV_USE_ASSERT_NULL 1
/*Checks is the memory is successfully allocated or no. (Quite fast)*/
#define LV_USE_ASSERT_MEM 1
/*Check the integrity of `lv_mem` after critical operations. (Slow)*/
#define LV_USE_ASSERT_MEM_INTEGRITY 0
/* Check the strings.
* Search for NULL, very long strings, invalid characters, and unnatural repetitions. (Slow)
* If disabled `LV_USE_ASSERT_NULL` will be performed instead (if it's enabled) */
#define LV_USE_ASSERT_STR 0
/* Check NULL, the object's type and existence (e.g. not deleted). (Quite slow)
#define LV_USE_ASSERT_OBJ 0
/*Check if the styles are properly initialized. (Fast)*/
#define LV_USE_ASSERT_STYLE 0
#endif /*LV_USE_DEBUG*/
* FONT USAGE
/* The built-in fonts contains the ASCII range and some Symbols with 4 bit-per-pixel.
* The symbols are available via `LV_SYMBOL_...` defines
* More info about fonts: https://docs.lvgl.com/#Fonts
* To create a new font go to: https://lvgl.com/ttf-font-to-c-array
/* Montserrat fonts with bpp = 4
* https://fonts.google.com/specimen/Montserrat */
#define LV_FONT_MONTSERRAT_12 0
#define LV_FONT_MONTSERRAT_14 0
#define LV_FONT_MONTSERRAT_16 1
#define LV_FONT_MONTSERRAT_18 0
#define LV_FONT_MONTSERRAT_20 0
#define LV_FONT_MONTSERRAT_22 0
#define LV_FONT_MONTSERRAT_24 0
#define LV_FONT_MONTSERRAT_26 0
#define LV_FONT_MONTSERRAT_28 0
#define LV_FONT_MONTSERRAT_30 0
#define LV_FONT_MONTSERRAT_32 0
#define LV_FONT_MONTSERRAT_34 0
#define LV_FONT_MONTSERRAT_36 0
#define LV_FONT_MONTSERRAT_38 0
#define LV_FONT_MONTSERRAT_40 0
#define LV_FONT_MONTSERRAT_42 0
#define LV_FONT_MONTSERRAT_44 0
#define LV_FONT_MONTSERRAT_46 0
#define LV_FONT_MONTSERRAT_48 0
/* Demonstrate special features */
#define LV_FONT_MONTSERRAT_12_SUBPX 0
#define LV_FONT_MONTSERRAT_28_COMPRESSED 0 /*bpp = 3*/
#define LV_FONT_DEJAVU_16_PERSIAN_HEBREW 0 /*Hebrew, Arabic, PErisan letters and all their forms*/
#define LV_FONT_SIMSUN_16_CJK 0 /*1000 most common CJK radicals*/
/*Pixel perfect monospace font
* http://pelulamu.net/unscii/ */
#define LV_FONT_UNSCII_8 0
/* Optionally declare your custom fonts here.
* You can use these fonts as default font too
* and they will be available globally. E.g.
* #define LV_FONT_CUSTOM_DECLARE LV_FONT_DECLARE(my_font_1) \
* LV_FONT_DECLARE(my_font_2)
/* Enable it if you have fonts with a lot of characters.
* The limit depends on the font size, font face and bpp
* but with > 10,000 characters if you see issues probably you need to enable it.*/
#define LV_FONT_FMT_TXT_LARGE 0
/* Set the pixel order of the display.
* Important only if "subpx fonts" are used.
* With "normal" font it doesn't matter.
#define LV_FONT_SUBPX_BGR 0
/*Declare the type of the user data of fonts (can be e.g. `void *`, `int`, `struct`)*/
typedef void * lv_font_user_data_t;
* THEME USAGE
/*Always enable at least on theme*/
/* No theme, you can apply your styles as you need
* No flags. Set LV_THEME_DEFAULT_FLAG 0 */
#define LV_USE_THEME_EMPTY 1
/*Simple to the create your theme based on it
#define LV_USE_THEME_TEMPLATE 1
/* A fast and impressive theme.
* Flags:
* LV_THEME_MATERIAL_FLAG_LIGHT: light theme
* LV_THEME_MATERIAL_FLAG_DARK: dark theme*/
#define LV_USE_THEME_MATERIAL 1
/* Mono-color theme for monochrome displays.
* If LV_THEME_DEFAULT_COLOR_PRIMARY is LV_COLOR_BLACK the
* texts and borders will be black and the background will be
* white. Else the colors are inverted.
#define LV_USE_THEME_MONO 1
#define LV_THEME_DEFAULT_INCLUDE <stdint.h> /*Include a header for the init. function*/
#define LV_THEME_DEFAULT_INIT lv_theme_material_init
#define LV_THEME_DEFAULT_COLOR_PRIMARY LV_COLOR_RED
#define LV_THEME_DEFAULT_COLOR_SECONDARY LV_COLOR_BLUE
#define LV_THEME_DEFAULT_FLAG LV_THEME_MATERIAL_FLAG_LIGHT
#define LV_THEME_DEFAULT_FONT_SMALL &lv_font_montserrat_16
#define LV_THEME_DEFAULT_FONT_NORMAL &lv_font_montserrat_16
#define LV_THEME_DEFAULT_FONT_SUBTITLE &lv_font_montserrat_16
#define LV_THEME_DEFAULT_FONT_TITLE &lv_font_montserrat_16
* Text settings
/* Select a character encoding for strings.
* - LV_TXT_ENC_UTF8
* - LV_TXT_ENC_ASCII
#define LV_TXT_BREAK_CHARS " ,.;:-_"
/* If a word is at least this long, will break wherever "prettiest"
* To disable, set to a value <= 0 */
#define LV_TXT_LINE_BREAK_LONG_LEN 0
/* Minimum number of characters in a long word to put on a line before a break.
* Depends on LV_TXT_LINE_BREAK_LONG_LEN. */
#define LV_TXT_LINE_BREAK_LONG_PRE_MIN_LEN 3
/* Minimum number of characters in a long word to put on a line after a break.
/* The control character to use for signalling text recoloring. */
#define LV_TXT_COLOR_CMD "#"
/* Support bidirectional texts.
* Allows mixing Left-to-Right and Right-to-Left texts.
* The direction will be processed according to the Unicode Bidirectioanl Algorithm:
* https://www.w3.org/International/articles/inline-bidi-markup/uba-basics*/
#define LV_USE_BIDI 0
#if LV_USE_BIDI
/* Set the default direction. Supported values:
* `LV_BIDI_DIR_LTR` Left-to-Right
* `LV_BIDI_DIR_RTL` Right-to-Left
* `LV_BIDI_DIR_AUTO` detect texts base direction */
#define LV_BIDI_BASE_DIR_DEF LV_BIDI_DIR_AUTO
/* Enable Arabic/Persian processing
* In these languages characters should be replaced with
* an other form based on their position in the text */
/*Change the built in (v)snprintf functions*/
#define LV_SPRINTF_CUSTOM 0
#if LV_SPRINTF_CUSTOM
# define LV_SPRINTF_INCLUDE <stdio.h>
# define lv_snprintf snprintf
# define lv_vsnprintf vsnprintf
#endif /*LV_SPRINTF_CUSTOM*/
* LV_OBJ SETTINGS
#if LV_USE_USER_DATA
/*Declare the type of the user data of object (can be e.g. `void *`, `int`, `struct`)*/
typedef void * lv_obj_user_data_t;
/*Provide a function to free user data*/
#define LV_USE_USER_DATA_FREE 0
#if LV_USE_USER_DATA_FREE
# define LV_USER_DATA_FREE_INCLUDE "something.h" /*Header for user data free function*/
/* Function prototype : void user_data_free(lv_obj_t * obj); */
# define LV_USER_DATA_FREE (user_data_free) /*Invoking for user data free function*/
/*1: enable `lv_obj_realaign()` based on `lv_obj_align()` parameters*/
#define LV_USE_OBJ_REALIGN 1
/* Enable to make the object clickable on a larger area.
* LV_EXT_CLICK_AREA_OFF or 0: Disable this feature
* LV_EXT_CLICK_AREA_TINY: The extra area can be adjusted horizontally and vertically (0..255 px)
* LV_EXT_CLICK_AREA_FULL: The extra area can be adjusted in all 4 directions (-32k..+32k px)
#define LV_USE_EXT_CLICK_AREA LV_EXT_CLICK_AREA_TINY
* LV OBJ X USAGE
* Documentation of the object types: https://docs.lvgl.com/#Object-types
/*Arc (dependencies: -)*/
#define LV_USE_ARC 1
/*Bar (dependencies: -)*/
#define LV_USE_BAR 1
/*Button (dependencies: lv_cont*/
#define LV_USE_BTN 1
/*Button matrix (dependencies: -)*/
#define LV_USE_BTNMATRIX 1
/*Calendar (dependencies: -)*/
#define LV_USE_CALENDAR 1
/*Canvas (dependencies: lv_img)*/
#define LV_USE_CANVAS 1
/*Check box (dependencies: lv_btn, lv_label)*/
#define LV_USE_CHECKBOX 1
/*Chart (dependencies: -)*/
#define LV_USE_CHART 1
#if LV_USE_CHART
# define LV_CHART_AXIS_TICK_LABEL_MAX_LEN 256
/*Container (dependencies: -*/
#define LV_USE_CONT 1
/*Color picker (dependencies: -*/
#define LV_USE_CPICKER 1
/*Drop down list (dependencies: lv_page, lv_label, lv_symbol_def.h)*/
#define LV_USE_DROPDOWN 1
#if LV_USE_DROPDOWN != 0
/*Open and close default animation time [ms] (0: no animation)*/
# define LV_DROPDOWN_DEF_ANIM_TIME 200
/*Gauge (dependencies:lv_bar, lv_linemeter)*/
#define LV_USE_GAUGE 1
/*Image (dependencies: lv_label*/
#define LV_USE_IMG 1
/*Image Button (dependencies: lv_btn*/
#define LV_USE_IMGBTN 1
#if LV_USE_IMGBTN
/*1: The imgbtn requires left, mid and right parts and the width can be set freely*/
# define LV_IMGBTN_TILED 0
/*Keyboard (dependencies: lv_btnm)*/
#define LV_USE_KEYBOARD 1
/*Label (dependencies: -*/
#define LV_USE_LABEL 1
#if LV_USE_LABEL != 0
/*Hor, or ver. scroll speed [px/sec] in 'LV_LABEL_LONG_ROLL/ROLL_CIRC' mode*/
# define LV_LABEL_DEF_SCROLL_SPEED 25
/* Waiting period at beginning/end of animation cycle */
# define LV_LABEL_WAIT_CHAR_COUNT 3
/*Enable selecting text of the label */
# define LV_LABEL_TEXT_SEL 0
/*Store extra some info in labels (12 bytes) to speed up drawing of very long texts*/
# define LV_LABEL_LONG_TXT_HINT 0
/*LED (dependencies: -)*/
#define LV_USE_LED 0
#if LV_USE_LED
# define LV_LED_BRIGHT_MIN 120 /*Minimal brightness*/
# define LV_LED_BRIGHT_MAX 255 /*Maximal brightness*/
/*Line (dependencies: -*/
#define LV_USE_LINE 1
/*List (dependencies: lv_page, lv_btn, lv_label, (lv_img optionally for icons ))*/
#define LV_USE_LIST 1
#if LV_USE_LIST != 0
/*Default animation time of focusing to a list element [ms] (0: no animation) */
# define LV_LIST_DEF_ANIM_TIME 100
/*Line meter (dependencies: *;)*/
#define LV_USE_LINEMETER 1
#if LV_USE_LINEMETER
/* Draw line more precisely at cost of performance.
* Useful if there are lot of lines any minor are visible
* 0: No extra precision
* 1: Some extra precision
* 2: Best precision
# define LV_LINEMETER_PRECISE 0
/*Mask (dependencies: -)*/
#define LV_USE_OBJMASK 1
/*Message box (dependencies: lv_rect, lv_btnm, lv_label)*/
#define LV_USE_MSGBOX 1
/*Page (dependencies: lv_cont)*/
#define LV_USE_PAGE 1
#if LV_USE_PAGE != 0
/*Focus default animation time [ms] (0: no animation)*/
# define LV_PAGE_DEF_ANIM_TIME 400
/*Preload (dependencies: lv_arc, lv_anim)*/
#define LV_USE_SPINNER 1
#if LV_USE_SPINNER != 0
# define LV_SPINNER_DEF_ARC_LENGTH 60 /*[deg]*/
# define LV_SPINNER_DEF_SPIN_TIME 1000 /*[ms]*/
# define LV_SPINNER_DEF_ANIM LV_SPINNER_TYPE_SPINNING_ARC
/*Roller (dependencies: lv_ddlist)*/
#define LV_USE_ROLLER 1
#if LV_USE_ROLLER != 0
/*Focus animation time [ms] (0: no animation)*/
# define LV_ROLLER_DEF_ANIM_TIME 200
/*Number of extra "pages" when the roller is infinite*/
# define LV_ROLLER_INF_PAGES 7
/*Slider (dependencies: lv_bar)*/
#define LV_USE_SLIDER 1
/*Spinbox (dependencies: lv_ta)*/
#define LV_USE_SPINBOX 1
/*Switch (dependencies: lv_slider)*/
#define LV_USE_SWITCH 1
/*Text area (dependencies: lv_label, lv_page)*/
#define LV_USE_TEXTAREA 1
#if LV_USE_TEXTAREA != 0
# define LV_TEXTAREA_DEF_CURSOR_BLINK_TIME 400 /*ms*/
# define LV_TEXTAREA_DEF_PWD_SHOW_TIME 1500 /*ms*/
/*Table (dependencies: lv_label)*/
#define LV_USE_TABLE 1
#if LV_USE_TABLE
# define LV_TABLE_COL_MAX 12
/*Tab (dependencies: lv_page, lv_btnm)*/
#define LV_USE_TABVIEW 1
# if LV_USE_TABVIEW != 0
/*Time of slide animation [ms] (0: no animation)*/
# define LV_TABVIEW_DEF_ANIM_TIME 300
/*Tileview (dependencies: lv_page) */
#define LV_USE_TILEVIEW 1
#if LV_USE_TILEVIEW
# define LV_TILEVIEW_DEF_ANIM_TIME 300
/*Window (dependencies: lv_cont, lv_btn, lv_label, lv_img, lv_page)*/
#define LV_USE_WIN 1
* Non-user section
#if defined(_MSC_VER) && !defined(_CRT_SECURE_NO_WARNINGS) /* Disable warnings for Visual Studio*/
# define _CRT_SECURE_NO_WARNINGS
/*--END OF LV_CONF_H--*/
#endif /*LV_CONF_H*/
