I am using lv_micropython to create an application. I have the latest commit and the firmware build fails.
$ git clone https://github.com/lvgl/lv_micropython.git
Commits on Mar 14, 2023 43ac0377a740559086a6d9aa550b1bf0bfa6e3d6
$ cd lv_micropython
$ git submodule update --init --recursive lib/lv_bindings
$ vim lib/lv_bindings/lv_conf.h
$ grep -i color_depth lib/lv_bindings/lv_conf.h
#ifndef LV_COLOR_DEPTH
#define LV_COLOR_DEPTH 16
$ make -C ports/rp2 BOARD=PICO submodules
$ make -C mpy-cross V=1
OK
$ make -C ports/rp2 BOARD=PICO USER_C_MODULES=../../lib/lv_bindings/bindings.cmake V=1
MPY _boot_fat.py
MPY rp2.py
MPY _boot.py
MPY ds18x20.py
MPY onewire.py
MPY dht.py
MPY uasyncio/__init__.py
MPY uasyncio/core.py
MPY uasyncio/event.py
MPY uasyncio/funcs.py
MPY uasyncio/lock.py
MPY uasyncio/stream.py
MPY neopixel.py
GEN /home/masahiro/lv_micropython/ports/rp2/build-PICO/frozen_content.c
[ 4%] Generating genhdr/moduledefs.split
[ 4%] Generating genhdr/moduledefs.collected
Module registrations updated
[ 4%] Generating genhdr/moduledefs.h
Scanning dependencies of target firmware
make[3]: γγ£γ¬γ―γγͺ '/home/masahiro/lv_micropython/ports/rp2/build-PICO' γγεΊγΎγ
make[3]: γγ£γ¬γ―γγͺ '/home/masahiro/lv_micropython/ports/rp2/build-PICO' γ«ε
₯γγΎγ
[ 4%] Building C object CMakeFiles/firmware.dir/home/masahiro/lv_micropython/py/argcheck.c.obj
In file included from /home/masahiro/lv_micropython/lib/lv_bindings/lvgl/src/misc/../draw/lv_img_buf.h:17,
from /home/masahiro/lv_micropython/lib/lv_bindings/lvgl/src/misc/../draw/lv_img_decoder.h:19,
from /home/masahiro/lv_micropython/lib/lv_bindings/lvgl/src/misc/../draw/lv_img_cache.h:16,
from /home/masahiro/lv_micropython/lib/lv_bindings/lvgl/src/misc/lv_gc.h:22,
from /home/masahiro/lv_micropython/ports/rp2/mpconfigport.h:190,
from /home/masahiro/lv_micropython/py/mpconfig.h:62,
from /home/masahiro/lv_micropython/py/mpstate.h:31,
from /home/masahiro/lv_micropython/py/runtime.h:29,
from /home/masahiro/lv_micropython/py/argcheck.c:30:
/home/masahiro/lv_micropython/lib/lv_bindings/lvgl/src/misc/../draw/../misc/lv_color.h: In function 'lv_color_mix':
/home/masahiro/lv_micropython/lib/lv_bindings/lvgl/src/misc/../draw/../misc/lv_color.h:589:23: error: dereferencing type-punned pointer will break strict-aliasing rules [-Werror=strict-aliasing]
589 | uint16_t c1_16 = *(uint16_t *)&c1;
/home/masahiro/lv_micropython/lib/lv_bindings/lvgl/src/misc/../draw/../misc/lv_color.h:590:23: error: dereferencing type-punned pointer will break strict-aliasing rules [-Werror=strict-aliasing]
590 | uint16_t c2_16 = *(uint16_t *)&c2;
cc1: all warnings being treated as errors
make[3]: *** [CMakeFiles/firmware.dir/build.make:699: CMakeFiles/firmware.dir/home/masahiro/lv_micropython/py/argcheck.c.obj] γ¨γ©γΌ 1
make[2]: *** [CMakeFiles/Makefile2:1329: CMakeFiles/firmware.dir/all] γ¨γ©γΌ 2
make[2]: γγ£γ¬γ―γγͺ '/home/masahiro/lv_micropython/ports/rp2/build-PICO' γγεΊγΎγ
make[1]: *** [Makefile:91: all] γ¨γ©γΌ 2
make[1]: γγ£γ¬γ―γγͺ '/home/masahiro/lv_micropython/ports/rp2/build-PICO' γγεΊγΎγ
make: *** [Makefile:27: all] γ¨γ©γΌ 2
make: γγ£γ¬γ―γγͺ '/home/masahiro/lv_micropython/ports/rp2' γγεΊγΎγ
Should I wait a little longer?
what version of LVGL are you running?
I also want to make sure you are using the correct build commands.
This is the order in which things need to be done.
cd lv_micropython
make -C ports/rp2 submodules
sudo apt update
sudo apt install cmake gcc-arm-none-eabi libnewlib-arm-none-eabi build-essential
make -C mpy-cross
cd ports/rp2
make BOARD=PICO USER_C_MODULES="../../lib/lv_bindings/bindings.cmake"
I believe that enclosing the USER_C_MODULES in double quotes. might have an effect on it. It did for the last user that had compilation issues when compiling for the RP2
What is the version of LVGL?
lv_micropython is the latest version of the LVGL master branch as it is cheked out in submodules.
I have been able to build with and without " UESR_C_MODULES= on mine.
Incidentally, I can BUILD with COLOR_DEPTH=32 without any problem, but with COLOR_DEPTH=16 I have some problems.
$ make -C ports/rp2 BOARD=PICO USER_C_MODULES="../../lib/lv_bindings/bindings.cmake" V=1
make: γγ£γ¬γ―γγͺ '/home/masahiro/lv_micropython/ports/rp2' γ«ε
₯γγΎγ
[ -e build-PICO/CMakeCache.txt ] || cmake -S . -B build-PICO -DPICO_BUILD_DOCS=0 -DMICROPY_BOARD=PICO -DUSER_C_MODULES=../../lib/lv_bindings/bindings.cmake
make -s -C build-PICO
make[1]: γγ£γ¬γ―γγͺ '/home/masahiro/lv_micropython/ports/rp2/build-PICO' γ«ε
₯γγΎγ
make[2]: γγ£γ¬γ―γγͺ '/home/masahiro/lv_micropython/ports/rp2/build-PICO' γ«ε
₯γγΎγ
₯γγΎγ
[ 0%] Built target bs2_default
₯γγΎγ
[ 1%] Built target bs2_default_padded_checksummed_asm
₯γγΎγ
₯γγΎγ
[ 1%] Performing build step for 'ELF2UF2Build'
make[4]: γγ£γ¬γ―γγͺ '/home/masahiro/lv_micropython/ports/rp2/build-PICO/elf2uf2' γ«ε
₯γγΎγ
make[5]: γγ£γ¬γ―γγͺ '/home/masahiro/lv_micropython/ports/rp2/build-PICO/elf2uf2' γ«ε
₯γγΎγ
make[6]: γγ£γ¬γ―γγͺ '/home/masahiro/lv_micropython/ports/rp2/build-PICO/elf2uf2' γ«ε
₯γγΎγ
Consolidate compiler generated dependencies of target elf2uf2
make[6]: γγ£γ¬γ―γγͺ '/home/masahiro/lv_micropython/ports/rp2/build-PICO/elf2uf2' γγεΊγΎγ
[100%] Built target elf2uf2
make[5]: γγ£γ¬γ―γγͺ '/home/masahiro/lv_micropython/ports/rp2/build-PICO/elf2uf2' γγεΊγΎγ
make[4]: γγ£γ¬γ―γγͺ '/home/masahiro/lv_micropython/ports/rp2/build-PICO/elf2uf2' γγεΊγΎγ
[ 1%] No install step for 'ELF2UF2Build'
[ 1%] Completed 'ELF2UF2Build'
[ 2%] Built target ELF2UF2Build
₯γγΎγ
[ 2%] Generating genhdr/mpversion.h
[ 2%] Generating frozen_content.c
Consolidate compiler generated dependencies of target firmware
₯γγΎγ
[ 2%] Building C object CMakeFiles/firmware.dir/home/masahiro/lv_micropython/py/argcheck.c.obj
masahiro@U2204LTS:~/lv_micropython$
This is related to this GitHub issue. I suggest continuing this discussion there:
opened 09:48PM - 03 Mar 23 UTC
### Describe the bug
ESP32 reports `dereferencing type-punned pointer will br⦠eak strict-aliasing rules` on `lv_color.h`:
[11/18] Building C object esp-idf/lvgl/CMakeFiles/__idf_lvgl.dir/src/misc/lv_color.c.obj
In file included from /home/amirgon/projects/lv_micropython/lib/lv_bindings/lvgl/src/misc/lv_color.c:9:
/home/amirgon/projects/lv_micropython/lib/lv_bindings/lvgl/src/misc/lv_color.h: In function 'lv_color_mix':
/home/amirgon/projects/lv_micropython/lib/lv_bindings/lvgl/src/misc/lv_color.h:590:42: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
uint32_t bg = (uint32_t)((uint32_t)(*(uint16_t *)&c2) | ((uint32_t)(*(uint16_t *)&c2) << 16)) &
/home/amirgon/projects/lv_micropython/lib/lv_bindings/lvgl/src/misc/lv_color.h:590:74: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
/home/amirgon/projects/lv_micropython/lib/lv_bindings/lvgl/src/misc/lv_color.h:592:42: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
uint32_t fg = (uint32_t)((uint32_t)(*(uint16_t *)&c1) | ((uint32_t)(*(uint16_t *)&c1) << 16)) & 0x7E0F81F;
/home/amirgon/projects/lv_micropython/lib/lv_bindings/lvgl/src/misc/lv_color.h:592:74: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
### To Reproduce
- Install esp-idf 4.4 (probably will happen with any other version as well)
- run `. ./export.sh` on esp-idf dir to setup esp-idf
- Build lv_micropython esp32 port with this command: `make -C ports/esp32 LV_CFLAGS="-DLV_COLOR_DEPTH=16" BOARD=GENERIC_SPIRAM`
This problem only happens when setting `LV_COLOR_DEPTH`
CC: @kisvegabor
I see this is an issue on lvgl github.
Thank you very much.
It should be fixed now in LVGL.
