Code Blocks c/c++ compiler
the package of the simulator. Do not know the release version.
After clicking the button I put on the same page, the text on the button should change from “Start” to “Running” and one needle of the gauge should move from 20 to 80, with a time interval of 5 seconds and a value interval of 5. After reaching the value of 80, the text on the button should become Reset.
Using a sleep() function to force the gauge to wait for 5 seconds after changing the value of the needle. But the process of changing the values is not shown when I was running the demo.
static lv_obj_t * gauge1;
static lv_obj_t * gauge_btn;
static lv_obj_t * gauge_button_label;
static void gauge_create(lv_obj_t * parent)
    /*Create a style*/
    static lv_style_t style;
    lv_style_copy(&style, &lv_style_pretty_color);
    style.body.main_color = lv_color_hex3(0x666);     /*Line color at the beginning*/
    style.body.grad_color =  lv_color_hex3(0x666);    /*Line color at the end*/
    style.body.padding.left = 10;                      /*Scale line length*/
    style.body.padding.inner = 8 ;                    /*Scale label padding*/
    style.body.border.color = lv_color_hex3(0x333);   /*Needle middle circle color*/
    style.line.width = 3;
    style.text.color = lv_color_hex3(0x333);
    style.line.color = LV_COLOR_RED;                  /*Line color after the critical value*/
    /*Describe the color for the needles*/
    static lv_color_t needle_colors[3];
    needle_colors[0] = LV_COLOR_BLUE;
    needle_colors[1] = LV_COLOR_ORANGE;
    needle_colors[2] = LV_COLOR_PURPLE;
    /*Create a gauge*/
    gauge1 = lv_gauge_create(parent, NULL);
    lv_gauge_set_style(gauge1, LV_GAUGE_STYLE_MAIN, &style);
    lv_gauge_set_needle_count(gauge1, 3, needle_colors);
    lv_obj_set_size(gauge1, 150, 150);
    lv_obj_align(gauge1, NULL, LV_ALIGN_IN_TOP_MID, 0, 20);
    /*Set the values*/
    lv_gauge_set_value(gauge1, 0, 10);
    lv_gauge_set_value(gauge1, 1, 20);
    lv_gauge_set_value(gauge1, 2, 30);
    gauge_btn = lv_btn_create(parent, NULL);
    lv_obj_set_event_cb(gauge_btn, gauge_button_event_handler);
    lv_obj_align(gauge_btn, NULL, LV_ALIGN_CENTER, 0, -40);
    gauge_button_label = lv_label_create(gauge_btn, NULL);
    lv_label_set_text(gauge_button_label, "Start");
static void gauge_button_event_handler(lv_obj_t * obj, lv_event_t event)
    static bool clicked = false;
    if(event == LV_EVENT_CLICKED){
        clicked = !clicked;
        if(clicked){
            lv_label_set_text(gauge_button_label, "Running");
            for(int16_t i = 20; i <= 80; i++){
                lv_gauge_set_value(gauge1, 1, i);
                sleep(5);
            lv_label_set_text(gauge_button_label, "Reset");
        else{
