Codeblocks simulator
7.5
I want to change screens after some period of time.
I tried use delay function, usleep.
Hi, probably really stupid question, but does anybody know how to change screens after some time in simulator?
I would use delay function or custom function with millis(), but I can not figure out what I have to use in simulator. I searched forum, but did not find solution similar to what I want to do.
I would like to achieve something like this:
startScreen(); // first screen after boot
delay(2000); // show this screen for 2 seconds
mainScreen(); //second screen
Many thanks for help.
You should create a oneshot lv_task
and switch screens inside it. Using a delay function generally doesn’t work with LVGL because it expects that all functions are nonblocking.
Disregard my comment just seen embeddedts response.
I’ve had this issue as well. When using lvgl platform io simulator, vscode(using windows.) I didn’t solve the in a simulator however I had the same issue when running my simulation on the raspberry pi and solved this issue.
Ill explain what I think is going on. This may help.
So for platform io the main loop consists of:
hal_setup();
demo_create();
hal_loop();
My demo_create() is the gui.
When you inspect the definition hal loop(); there is a while loop which consists of a timer.
A suggestion maybe try to reconfigure the hal loop function and place your screen with the timer code in there.
I’ll try to provide a more detailed post when I’m free. Hope this helps a little bit. If you have already solved the issue please can you let me know how you did it.
ONCE TASK Should be an excellent solution, for example:
lv_task_t * load_screen2_task_handle;
void load_screen2_task_cb(lv_obj_t* obj, lv_event_t event)
lv_scr_load(screen2);
void screen1_create(void)
load_screen2_task_handle=lv_task_create(load_screen2_task_cb,delay_time,LV_TASK_PRIO_LOW,NULL);
lv_task_once(load_screen2_task_handle);
I often use this method to close the prompt window automatically.
