Simplest C example for fbdev and evdev (no SDL)?
Looking for a simple example using evdev to get input from a touchscreen
OdroidN2 Linux SBC with Ubuntu 18.04 headless, no SDL, no X11, gcc 8.4.0, latest LittleVGL from github with all submodules
Trying to find a very simple demo app with 1 button to be clicked via touchscreen (which is a /dev/input/event device)
I have the “Hello World!” demo app working on fbdev.
I have found that my touchscreen works with “evtest” and corresponds to /dev/input/event3
I configured lv_drv_conf.h to enable the EVDEV input driver.
But, I could not find a basic-level sample source code to learn the basics of touchscreen input (like: clicking a button and showing a text)
If you have the evdev driver enabled, this code needs to be present when you initialize LittlevGL:
    evdev_init();
    lv_indev_drv_t indev_drv;
    indev_drv.read_cb = evdev_read;
After that, you can create buttons or other widgets as per the examples and they automatically get touchscreen input. If you want a simple example with one button you can take a look at the button documentation.
Thank you very much.
Unfortunately, I can’t seem to have it working: the button won’t get pressed.
My source code:
#include "lvgl/lvgl.h"
#include "lv_drivers/display/fbdev.h"
#include "lv_drivers/indev/evdev.h"
#include <stdio.h>
#include <unistd.h>
#define DISP_BUF_SIZE 800*480*4UL // If smaller than screen memory, draw will occur in chunks
        printf("Clicked\n");
    else if(event == LV_EVENT_VALUE_CHANGED) {
        printf("Toggled\n");
void lv_ex_btn_1(void)
    lv_obj_t * label;
    lv_obj_t * btn1 = lv_btn_create(lv_scr_act(), NULL);
    lv_obj_set_event_cb(btn1, event_handler);
    lv_obj_align(btn1, NULL, LV_ALIGN_CENTER, 0, -40);
    label = lv_label_create(btn1, NULL);
    lv_obj_t * btn2 = lv_btn_create(lv_scr_act(), NULL);
    lv_obj_set_event_cb(btn2, event_handler);
    lv_obj_align(btn2, NULL, LV_ALIGN_CENTER, 0, 40);
    lv_btn_set_toggle(btn2, true);
    lv_btn_toggle(btn2);
    lv_btn_set_fit2(btn2, LV_FIT_NONE, LV_FIT_TIGHT);
    label = lv_label_create(btn2, NULL);
    lv_label_set_text(label, "Toggled");
int main(void)
    /*LittlevGL init*/
    /*Linux frame buffer device init*/
    fbdev_init();
    /*Small buffers for LittlevGL to draw the screen's content with double-buffering*/
    static lv_color_t buf1[DISP_BUF_SIZE];
    static lv_color_t buf2[DISP_BUF_SIZE];
    /*Initialize a descriptor for the buffer, with double buffering*/
    lv_disp_buf_init(&disp_buf, buf1, buf2, DISP_BUF_SIZE);
    /*Initialize and register a display driver*/
    // Here we use the special callback function specific for the Linux Framebuffer Driver
    lv_disp_drv_t disp_drv;
    lv_disp_drv_init(&disp_drv);
    disp_drv.buffer = &disp_buf;
    // Initialize EVDEV input for the 52pi touchscreen,
    // which luckily is supported as an "event input device" by the kernel
    evdev_init();
    //Create a label. Style is NULL by default for labels
    lv_obj_t * label1 = lv_label_create(lv_scr_act(), NULL);
    lv_label_set_text(label1, "Function 1");
    lv_obj_t * label2 = lv_label_create(lv_scr_act(), NULL);
    lv_label_set_text(label2, "Section A");
    // Alignment
    // NULL = align on parent (the screen)
    lv_obj_align(label1, NULL, LV_ALIGN_IN_TOP_LEFT, 0, 0);
    lv_obj_align(label2, NULL, LV_ALIGN_IN_TOP_MID, 0, 0);
    // Add a button
    lv_ex_btn_1();
    /*Handle LitlevGL tasks (tickless mode)*/
    // Mandatory, otherwise nothing will be displayed
    // It allows the callback functions to operate (for example to actually transfer bytes to screen framebuffer)
    while(1)
        lv_tick_inc(5);
        lv_task_handler();
        usleep(5000);
    return 0;
The relevant section of my lv_drv_conf.h:
 * Mouse or touchpad as evdev interface (for Linux based systems)
#ifndef USE_EVDEV
#define USE_EVDEV           1
#if USE_EVDEV
#define EVDEV_NAME   "/dev/input/event3"        /*You can use the "evtest" Linux tool to get the list of devices and test them*/
#  define EVDEV_SWAP_AXES         0               /*Swap the x and y axes of the touchscreen*/
#define EVDEV_SCALE             1               /* Scale input, e.g. if touchscreen resolution does not match display resolution */
#if EVDEV_SCALE
#define EVDEV_SCALE_HOR_RES     (16384)          /* Horizontal resolution of touchscreen */
#define EVDEV_SCALE_VER_RES     (9600)          /* Vertical resolution of touchscreen */
#endif  /*EVDEV_SCALE*/
#  define EVDEV_CALIBRATE         0               /*Scale and offset the touchscreen coordinates by using maximum and minimum values
#  if EVDEV_CALIBRATE
#    define EVDEV_HOR_MIN   3800                    /*If EVDEV_XXX_MIN > EVDEV_XXX_MAX the XXX axis is automatically inverted*/
#    define EVDEV_HOR_MAX   200
#    define EVDEV_VER_MIN   200
#    define EVDEV_VER_MAX   3800
#  endif  /*EVDEV_SCALE*/
#endif  /*USE_EVDEV*/
The output of evtest on /dev/input/event3:
Input driver version is 1.0.1
Input device ID: bus 0x3 vendor 0x222a product 0x1 version 0x110
Input device name: "ILITEK ILITEK-TP"
Supported events:
  Event type 0 (EV_SYN)
  Event type 1 (EV_KEY)
    Event code 330 (BTN_TOUCH)
  Event type 3 (EV_ABS)
    Event code 0 (ABS_X)
      Value   8268
      Min        0
      Max    16384
      Resolution      34
    Event code 1 (ABS_Y)
      Value   4016
      Min        0
      Max     9600
      Resolution      36
    Event code 47 (ABS_MT_SLOT)
      Value      0
      Min        0
      Max        9
    Event code 53 (ABS_MT_POSITION_X)
      Value      0
      Min        0
      Max    16384
      Resolution      34
    Event code 54 (ABS_MT_POSITION_Y)
      Value      0
      Min        0
      Max     9600
      Resolution      36
    Event code 57 (ABS_MT_TRACKING_ID)
      Value      0
      Min        0
      Max    65535
Properties:
  Property type 1 (INPUT_PROP_DIRECT)
Testing ... (interrupt to exit)
Event: time 1587772644.579822, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value 82
Event: time 1587772644.579822, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 6190
Event: time 1587772644.579822, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 6005
Event: time 1587772644.579822, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1587772644.579822, type 3 (EV_ABS), code 0 (ABS_X), value 6190
Event: time 1587772644.579822, type 3 (EV_ABS), code 1 (ABS_Y), value 6005
Event: time 1587772644.579822, -------------- SYN_REPORT ------------
Event: time 1587772644.649793, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value -1
Event: time 1587772644.649793, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1587772644.649793, -------------- SYN_REPORT ------------
What happens if you add printf statements inside evdev_read? Do you see any events getting read?
Added a debug print in evdev.c:
bool evdev_read(lv_indev_drv_t * drv, lv_indev_data_t * data)
    struct input_event in;
    fprintf(stdout, "\nevdev_read() DEBUG:\n\n");
    while(read(evdev_fd, &in, sizeof(struct input_event)) > 0)
        fprintf(stdout, "in.type=%d, in.code=%d, in.value=%d\n", in.type, in.code, in.value);
Touching on the button I get this:
evdev_read() DEBUG:
in.type=3, in.code=57, in.value=-1
in.type=1, in.code=330, in.value=0
in.type=0, in.code=0, in.value=0
so it is actually called, don’t know about the values…?
Thanks a lot for your support!
Solved!!
It was not enough to specify X and Y resolution in the EVDEV section of lv_drv_conf.h
Calibration points were needed too:
#ifndef USE_EVDEV
#define USE_EVDEV           1
#if USE_EVDEV
#if EVDEV_SCALE
#define EVDEV_CALIBRATE         1               /*Scale and offset the touchscreen coordinates by using maximum and minimum values for each axis*/
#    define EVDEV_HOR_MIN   25 //3800                    /*If EVDEV_XXX_MIN > EVDEV_XXX_MAX the XXX axis is automatically inverted*/
#    define EVDEV_HOR_MAX   16383 // 200
#    define EVDEV_VER_MIN   45 //200
#    define EVDEV_VER_MAX   9592 // 3800
I determined the extreme points (EVDEV_HOR_MIN etc.) using “evtest” and clicking the corners.
Thanks for tipping me in the right direction!
Tested the same solution on iMX7 (Cortex-A7) and also worked. Headless linux, no SLD, no X11, gcc 7.3.0.
