Is there a simple demo that shows this “basic” configuration in action so one can easily get started and check that the HW is connected correctly? Something simple, like a button one can press and see something happen…
They’re rather confusing 'cause they use ILI9341 while the recommended default use is now ili9341… I ended up doing double init which caused a firmware crash and sent me down a rather unproductive path…
Also, I tried example2, which has inline image data, and I eventually got an image, but it was just noise…
Hi @tve,
You can try https://github.com/lvgl/lv_binding_micropython/blob/master/examples/advanced_demo.py
It uses ili9341 and xpt2046 python drivers when running on esp32. You can also run it on the Linux port and very recently stm32 was also added.
For a simpler example, just displaying a button, you can load the driver by https://github.com/lvgl/lv_binding_micropython/blob/master/lib/display_driver.py (change it to match the correct pins of your hardware) and run something like
scr = lv.obj()
btn = lv.btn(scr)
btn.align(scr, lv.ALIGN.CENTER, 0, 0)
label = lv.label(btn)
label.set_text('Hello World!')
lv.scr_load(scr)
