On hardware the textarea starts to cause a significant drop in framerate while trying to scroll when having a large amount of text to display.
LVGL simulator for Visual Studios
9.0.0 dev
I want to be able to limit the amount of characters to display in a textarea. When that limit is reached start removing the characters at the top of the textarea. If scrolling back up start adding back in the removed characters at the top and start removing the new characters from the bottom, so as to always stay below the set character limit.
#define LV_LABEL_LONG_TXT_HINT 1
Unfortunately this didn’t help with the issue. So I must think of a work around, at about 15,000 characters scrolling on the textarea drops frames below 13fps and it no longer feels fluid.
My initial idea is in the lv_textarea_add_text
check if the text you want to add would bring you over the preset textarea max length (set by lv_textarea_set_max_length
). If true have two loops, an inner loop that just counts how many characters until you reached a new line '\n'
and the outer checks if the current textarea’s text length + new text to add’s length - counter is less than the max length. Essentially loops through until it finds how many lines to remove until you new text can fit in without going over the max length.
The also make an event callback set for LV_EVENT_SCROLL
on the textarea, use the indev to find the direction of the scroll. If scrolling up add characters in at the top (line by line) while remove characters at the bottom (line by line).
No, code at the moment. The idea (or my implementation of it) I had is failing utterly.
