I want to use sharp memory LCD with lvgl. I see that there is a driver for this type of displays, but it’s not clear to me how to use the driver. I read the porting guide, maybe I didn’t understand it well.
nRF52840, Keil MDK
Set up a project with FreeRTOS that drives Sharp MIP display
I have a driver that transfers the display buffer data to the display using DAM, but my port of lvgl doesn’t drive the display yet.
#include "lv_conf.h"
#include "lvgl.h"
int main(void)
static lv_disp_buf_t disp_buf; /*A static or global variable to store the buffers*/
static lv_color_t buf_1[LV_HOR_RES_MAX * 10]; /*Static or global buffer(s). The second buffer is optional*/
static lv_color_t buf_2[LV_HOR_RES_MAX * 10];
lv_disp_buf_init(&disp_buf, buf_1, buf_2, LV_HOR_RES_MAX*10);/*Initialize `disp_buf` with the buffer(s) */
lv_disp_drv_t disp_drv; /*A variable to hold the drivers. Can be local variable*/
disp_drv.buffer = &disp_buf; /*Set an initialized buffer*/
disp_drv.flush_cb = sharp_mip_flush; /*Set a flush callback to draw to the display*/
disp_drv.rounder_cb = sharp_mip_rounder;
disp_drv.set_px_cb = sharp_mip_set_px;
lv_disp_t * disp;
disp = lv_disp_drv_register(&disp_drv); /*Register the driver and save the created display objects*/
When I try to compile it I get:
..\..\..\main.c(113): error: #20: identifier "sharp_mip_flush" is undefined ..\..\..\main.c(114): error: #20: identifier "sharp_mip_rounder" is undefined ..\..\..\main.c(115): error: #20: identifier "sharp_mip_set_px" is undefined
If I add #include "SHARP_MIP.h" in the include section I get this error:
..\..\..\main.c(58): error: #130: expected a "{"
It looks to my like there is a typo in SHARP_MIP.h
I know my code is not complete, I’m building after each step from the porting guide. Does this make any sense?
Okay, the error doesn’t show. I searched all lvgl and lv_driver filex for sharp_mip.h and it’s not included enywhere. Then the “my build test” error is normal not to show.
If I add #include "SHARP_MIP".h in the main.c include section I get this error:
