Hi, I’ve a project that mount an SD card with SPI shared with ILI9488 TFT
Actually I’m using LVGL 9 with Lovyangfx library.
SD card is mounted at setup and succesfully open 9 PNG files (tiles) and create a Sprite that contains a map.
In first run of the program I can create the Sprite (from files stored in SD) and display It in the screen (actually i don’t use lvgl Canvas, i put the Sprite direct in screen)
But when LVGL task start (I think this is the problem), SD is already mounted but can’t open another file, for example if i need to generate a new sprite from png files stored in SD or open any file stored in SD.
I’ve checked a lot of things without success always returns error opening file.
I’ve checked also a little program to test SD card with the TFT (without LVGL) and I can read and write files without problems.
I don’t know if really is a problem with LVGL task that always blocks the SPI during screen flush… or something else.
I’ve also tryied to stop lvgl timer, task, etc … (Maybe I’m doing bad this)
ESP32-S3 N16R8
ILI9488 TFT with SD module sharing SPI Bus
FT6326 TOUCH
LOVYANGFX
LVGL 9.1
9.1
Use standard FS open without LVGL Filesystem
- SD file operations with TFT without LVGL (it’s works)
- SD file operations with TFT and LVGL (it’s works one time in first run, after this doesn’t works)
- Try to “stop” LVGL timer, task, (screen doesn’t refresh but I can’t open any file)
- Manually set different SPI CS high or low when access to SD.
Someone had this problem or similar? Sharing SD SPI or other SPI device with LVGL?
Thank you
