- if I create a button matrix, its width may be 600, it consists of 3 buttons(like A, B, C),so each button’s width is 200. how to hide one the last button©, but each button’s width is still 200, I just hide the last button, but not change the whole size of the button matrix.
2.below is my code, I want to set the button matrix should has one button pressed everytime.
I set the button A pressed first, when I run the code, I clicked the button A, it turn to the unpressed. What I want is even if I always clicked the same button of in a button matrix, it should be pressed always.
eclipse
static void btnm_event_cb(lv_obj_t* btnm, lv_event_t event)
if (event != LV_EVENT_CLICKED)
return;
void main ()
static const char* btnm_map[] = {"CH A", "CH B", "CH C", ""};
btnm = lv_btnm_create(parent, NULL);
lv_btnm_set_map(btnm, btnm_map);
lv_obj_set_size(btnm, 600, 33);
lv_btnm_set_btn_ctrl_all(btnm, LV_BTNM_CTRL_TGL_ENABLE);
lv_btnm_set_one_toggle(btnm, true);
lv_btnm_set_pressed(btnm, 0);
lv_obj_align(btnm, NULL, LV_ALIGN_CENTER, 0, 0);
lv_obj_set_event_cb(btnm, btnm_event_cb);
static lv_style_t style_btnm_bg;
lv_style_copy(&style_btnm_bg, &lv_style_pretty);
style_btnm_bg.body.padding.top = 0;
style_btnm_bg.body.padding.bottom = 0;
style_btnm_bg.body.padding.left = 0;
style_btnm_bg.body.padding.right = 0;
style_btnm_bg.body.padding.inner = 0;
static lv_style_t style_btnm_rel;
lv_style_copy(&style_btnm_rel, &lv_style_btn_rel);
style_btnm_rel.body.radius = 0;
style_btnm_rel.body.padding.top = 0;
style_btnm_rel.body.padding.bottom = 0;
style_btnm_rel.body.padding.left = 0;
style_btnm_rel.body.padding.right = 0;
style_btnm_rel.body.border.part = LV_BORDER_LEFT | LV_BORDER_RIGHT;
style_btnm_rel.body.border.width = 1;
static lv_style_t style_btnm_pr;
lv_style_copy(&style_btnm_pr, &lv_style_btn_pr);
style_btnm_pr.body.radius = 0;
style_btnm_pr.body.border.part = LV_BORDER_LEFT | LV_BORDER_RIGHT;
style_btnm_pr.body.border.width = 1;
static lv_style_t style_btnm_tgl_rel;
lv_style_copy(&style_btnm_tgl_rel, &lv_style_btn_tgl_rel);
style_btnm_tgl_rel.body.radius = 0;
style_btnm_tgl_rel.body.border.part = LV_BORDER_LEFT | LV_BORDER_RIGHT;
style_btnm_tgl_rel.body.border.width = 1;
static lv_style_t style_btnm_tgl_pr;
lv_style_copy(&style_btnm_tgl_pr, &lv_style_btn_tgl_pr);
style_btnm_tgl_pr.body.radius = 0;
style_btnm_tgl_pr.body.border.part = LV_BORDER_LEFT | LV_BORDER_RIGHT;
style_btnm_tgl_pr.body.border.width = 1;
lv_btnm_set_style(btnm, LV_BTNM_STYLE_BG, &style_btnm_bg);
lv_btnm_set_style(btnm, LV_BTNM_STYLE_BTN_REL, &style_btnm_rel);
lv_btnm_set_style(btnm, LV_BTNM_STYLE_BTN_PR, &style_btnm_pr);
lv_btnm_set_style(btnm, LV_BTNM_STYLE_BTN_TGL_REL, &style_btnm_tgl_rel);
lv_btnm_set_style(btnm, LV_BTNM_STYLE_BTN_TGL_PR, &style_btnm_tgl_pr);
