I’m trying to put all my image .bin files in an sd card to lighten the program size, so I am trying to setup the filesystem. I was told that POSIX was the way to go but I’m running into problems where the SD card is detected but the f_open function is returning null. What am I doing wrong?
ESP 32 Devkit on Arduino IDE
8.3
Setup POSIX File system to be able to use an image on an SD Card for LVGL widgets
See below
Enabled POSIX file system in lv_conf.h
#define LV_USE_FS_POSIX 1
#if LV_USE_FS_POSIX
#define LV_FS_POSIX_LETTER 'S'
#define LV_FS_POSIX_PATH "/"
#define LV_FS_POSIX_CACHE_SIZE 512
then in my .ino file I added the following:
#define SCK 18
#define MISO 19
#define MOSI 23
#define CS 5
SPIClass spi = SPIClass(VSPI);
spi.begin(SCK, MISO, MOSI, CS);
if (!SD.begin(CS, spi)) {
Serial.println("Card Mount Failed");
return;
uint8_t cardType = SD.cardType();
if (cardType == CARD_NONE) {
Serial.println("No SD card attached");
return;
Serial.print("SD Card Type: ");
if (cardType == CARD_MMC) {
Serial.println("MMC");
} else if (cardType == CARD_SD) {
Serial.println("SDSC");
} else if (cardType == CARD_SDHC) {
Serial.println("SDHC");
} else {
Serial.println("UNKNOWN");
uint64_t cardSize = SD.cardSize() / (1024 * 1024);
Serial.printf("SD Card Size: %lluMB\n", cardSize);
Serial.println("initialisation done.");
Serial.println("initializing posix init...");
lv_fs_posix_init();
Serial.println("posix init done...");
lv_obj_t * img_bin = lv_img_create(lv_scr_act());
lv_img_set_src(img_bin, "S:/Baboon40.bin");
lv_obj_align(img_bin, LV_ALIGN_CENTER, 0, 0);
lv_obj_set_size(img_bin, 320,480);
then inside the fs_open function of lv_fs_posix.c, I added logging in lines 119:
int f = open(buf, flags);
if(f < 0) {
printf("open returned null :( \r\n");
return NULL;
my logs in the serial monitor is this:
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0030,len:1344
load:0x40078000,len:13864
load:0x40080400,len:3608
entry 0x400805f0
Hello Arduino! V8.3.1
I am LVGL_Arduino
SD Card Type: SDHC
SD Card Size: 14910MB
lv_fs_posix_init
lv_fs_posix_init
posix init done...
fs_open
