If I’m understanding correctly, it sounds like lv_obj_scroll_to_y(obj, <y_coord>, LV_ANIM_OFF) is what you want. I think (though I haven’t tested) that you can pass LV_COORD_MAX to scroll to the bottom.
You would want to invoke that after appending more content to the object.
It may also be necessary to call lv_obj_update_layout(obj) before scrolling; I’m not 100% sure.
Hi embeddedt!!!
thanks for the answer. Yes " lv_obj_scroll_to_y" is exactly what a need. I was a bit blind searching in the doc… I’m very grateful
P.D. Is no necesary to use v_obj_update_layout
RECTIFICATION
it is necessary to use the function lv_obj_update_layout
