When I set LV_COLOR_SCREEN_TRANSP to 1, the LCD only display black without anything else. If clear LV_COLOR_SCREEN_TRANSP to 0, the LCD can display my application (rectangle filled with red color drawn in canvas)
LPC54608, TFT lcd
I want to implement opacity display. (a background picture and a rectangle with a specify opacity value)
#define LV_COLOR_DEPTH 32
#define LV_COLOR_SCREEN_TRANSP 1
memset((uint32_t *)CANVAS_RECT_BUF_ADDR, 0x00, CANVAS_RECT_BUF_SIZE);
lv_obj_t *canvas_rect = lv_canvas_create(lv_scr_act(), NULL);
lv_canvas_set_buffer(canvas_rect, (uint32_t *)CANVAS_RECT_BUF_ADDR, CANVAS_RECT_BUF_W, CANVAS_RECT_BUF_H, LV_IMG_CF_TRUE_COLOR);
lv_style_t canvas_rect_style;
lv_style_copy(&canvas_rect_style, &lv_style_plain);
canvas_rect_style.body.main_color = LV_COLOR_RED;
canvas_rect_style.body.grad_color = LV_COLOR_RED;
canvas_rect_style.body.opa = LV_OPA_100;
lv_canvas_draw_rect(canvas_rect, 0, 0, 124, 124, &canvas_rect_style);
lv_obj_set_x(canvas_rect, 0);
lv_obj_set_y(canvas_rect, 0);
Are you trying to display LittlevGL on top of an existing framebuffer (drawn by another graphics library) or do you just want to draw a translucent rectangle on top of a regular image?
If it’s the latter, you don’t need LV_COLOR_SCREEN_TRANSP
or lv_canvas
. Simply create an image object to draw your image with, then create a base object and set its style to canvas_rect_style
to draw your rectangle.
Thanks for your reply.
I want to display a screen like the screenshot below:
I will change the rectangle coordinate pixel by pixel with a timer.
In the lv_sim_visual_studio_sdl simulator, I create a canvas and enable LV_COLOR_SCREEN_TRANSP, draw the rectangle successfully. But with the LPC54608 platform, if enable LV_COLOR_SCRREN_TRANSP, the LCD is black.
And I tried as you said to draw the rectangle by lv_draw_rect(), the lcd display a back screen again.
Is there anything wrong in my driver or application code?
The application code is as below:
void demo_create(void)
lv_obj_t * wp = lv_img_create(lv_scr_act(), NULL);
lv_img_set_src(wp, &test);
lv_obj_set_width(wp, LV_HOR_RES * 4);
lv_obj_set_protect(wp, LV_PROTECT_POS);
lv_style_t style;
lv_style_copy(&style, &lv_style_plain);
lv_area_t area = {.x1=0,.y1=0,.x2=50,.y2=50};
lv_area_t mask = {.x1=0,.y1=0,.x2=100,.y2=100};
lv_draw_rect(&area, &mask, &style, LV_OPA_100); //if comment this function call, lcd can display the wallpaper fine.
return;
Why are you trying to use lv_draw_rect
? Why don’t you just create an lv_obj
like I suggested above and apply the style you had created to it?
Got it, sorry for misunderstanding your reply.
Thank you very much.
#if LV_DEMO_WALLPAPER
#endif /* #if LV_DEMO_WALLPAPER */
lv_obj_t *test = lv_obj_create(lv_scr_act(), NULL);
lv_style_t style;
style.body.opa = LV_OPA_20;
lv_obj_set_style(test, &style);
lv_obj_set_x(test, 50);
lv_obj_set_y(test, 70);
