I use label object to refresh some datas in a task, because data’s length is flexible, so I use function lv_label_set_static_text , and I set the long mode LV_LABEL_LONG_SCROLL_CIRC , but it doesn’t work. But If I put the document’s example code it works well. It confused me.
/*\brief clear_all_table_cells
* 清除整个表格的所有单元格
static void clear_all_table_cells(void)
/* 清空序号 */
for (int i = ALARMINFO_ROW1; i < ALARMINFO_ROWNUM; i++)
lv_table_set_cell_value(AlarmInfoObj.AlarmInfoTable, i, ALARMINFO_COL1, " ");
for (int i = ALARM_1; i < ALARM_NUM; i++)
memset(AlarmInfoRuntime.EventTimeStr[i], 0, sizeof(AlarmInfoRuntime.EventTimeStr[i]));
memset(AlarmInfoRuntime.EventPointStr[i], 0, sizeof(AlarmInfoRuntime.EventPointStr[i]));
memset(AlarmInfoRuntime.EventTypeStr[i], 0, sizeof(AlarmInfoRuntime.EventTypeStr[i]));
memset(AlarmInfoRuntime.EventDescStr[i], 0, sizeof(AlarmInfoRuntime.EventDescStr[i]));
strncpy(AlarmInfoRuntime.EventTimeStr[i], "", MAX_NAME_LEN);
strncpy(AlarmInfoRuntime.EventPointStr[i], "", MAX_NAME_LEN);
strncpy(AlarmInfoRuntime.EventTypeStr[i], "", MAX_NAME_LEN);
strncpy(AlarmInfoRuntime.EventDescStr[i], "", 4 * MAX_NAME_LEN);
lv_label_set_static_text(AlarmInfoObj.EventTime[i], AlarmInfoRuntime.EventTimeStr[i]);
lv_label_set_static_text(AlarmInfoObj.EventPoint[i], AlarmInfoRuntime.EventPointStr[i]);
lv_label_set_static_text(AlarmInfoObj.EventType[i], AlarmInfoRuntime.EventTypeStr[i]);
lv_label_set_static_text(AlarmInfoObj.EventDesc[i], AlarmInfoRuntime.EventDescStr[i]);
lv_obj_set_hidden(AlarmInfoObj.AlarmLevelPage[i], true);
/*\brief refresh_alarm_event_table
static void refresh_alarm_event_table(void)
/* 先清空缓存 */
clear_all_table_cells();
if (!gEvent.HMIEvent.cnt)
return;
/* 计算起始 */
uint16_t start = ALARM_NUM * (PageFlag.CurPage - 1);
/* 确定结束位置 */
uint16_t refreshNum;
if (PageFlag.CurPage == PageFlag.TotPage)
if (!(gEvent.HMIEvent.cnt % ALARM_NUM))
refreshNum = ALARM_NUM;
refreshNum = gEvent.HMIEvent.cnt % ALARM_NUM;
/* 刷新表格, 写序号 */
char tempsn[MAX_NAME_LEN];
char TempModel[MAX_NAME_LEN];
for (int i = ALARM_1; i < refreshNum; i++)
/* 设置属性,先改长模式,然后再设置宽度 */
lv_label_set_long_mode(AlarmInfoObj.EventPoint[i], LV_LABEL_LONG_SROLL_CIRC);
lv_label_set_long_mode(AlarmInfoObj.EventType[i], LV_LABEL_LONG_SROLL_CIRC);
lv_label_set_long_mode(AlarmInfoObj.EventDesc[i], LV_LABEL_LONG_SROLL_CIRC);
lv_obj_set_width(AlarmInfoObj.EventPoint[i], 210);
lv_obj_set_width(AlarmInfoObj.EventType[i], 140);
lv_obj_set_width(AlarmInfoObj.EventDesc[i], 440);
/* 写入编号 */
memset(tempsn, 0, sizeof(tempsn));
snprintf(tempsn, MAX_NAME_LEN, "%5d", start + 1 +i);
ALARMINFO_ROW1 + i % ALARM_NUM,
ALARMINFO_COL1 + 4 * (i / ALARM_NUM), tempsn);
/* 更新告警点位信息 */
strncpy(AlarmInfoRuntime.EventPointStr[i], gEvent.HMIEvent.events[start + i].pointName, MAX_NAME_LEN);
/* 更新事件类型信息,转换成中文 */
memset(TempModel, 0, sizeof(TempModel));
eventmodel_str_deal(TempModel, gEvent.HMIEvent.events[start + i]);
strncpy(AlarmInfoRuntime.EventTypeStr[i], TempModel, MAX_NAME_LEN);
/* 更新事件描述 */
strncpy(AlarmInfoRuntime.EventDescStr[i], gEvent.HMIEvent.events[start + i].stationName, MAX_NAME_LEN);
strcat(AlarmInfoRuntime.EventDescStr[i], gEvent.HMIEvent.events[start + i].equipmentName);
strcat(AlarmInfoRuntime.EventDescStr[i], gEvent.HMIEvent.events[start + i].logicDevName);
/*TODO TEST */
lv_label_set_long_mode(AlarmInfoObj.EventPoint[ALARM_10], LV_LABEL_LONG_SROLL_CIRC);
lv_label_set_long_mode(AlarmInfoObj.EventType[ALARM_10], LV_LABEL_LONG_SROLL_CIRC);
lv_label_set_long_mode(AlarmInfoObj.EventDesc[ALARM_10], LV_LABEL_LONG_SROLL_CIRC);
lv_obj_set_width(AlarmInfoObj.EventPoint[ALARM_10], 210);
lv_obj_set_width(AlarmInfoObj.EventType[ALARM_10], 140);
lv_obj_set_width(AlarmInfoObj.EventDesc[ALARM_10], 440);
lv_label_set_text(AlarmInfoObj.EventPoint[ALARM_10], "12344567890ABCDEFGHIJKLMNOPQRSTUVWXYZ");
lv_label_set_text(AlarmInfoObj.EventType[ALARM_10], "12344567890ABCDEFGHIJKLMNOPQRSTUVWXYZ");
lv_label_set_text(AlarmInfoObj.EventDesc[ALARM_10], "12344567890ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopq");
