ESP32 lvgl v6
Hi All , i want to set focus to newly created object. I have a six buttons and my goal is to fade buttons,
except selected.
I tried to create new object that “covers” buttons with alpha, and then to create desired button over the new object. My problem is that i cant set focus to newly created button and gndbtn_a_event_cb(…) cant be executed.
main.c
lv_disp_drv_t disp_drv;
lv_disp_drv_init(&disp_drv);
disp_drv.flush_cb = ili9341_flush;
disp_drv.buffer = &disp_buf;
lv_indev_t * enc_main_indev;
lv_indev_drv_t indev_main;
lv_indev_drv_init(&indev_main);
indev_main.read_cb = rot_enc_get_data;
indev_main.type = LV_INDEV_TYPE_ENCODER;
enc_main_indev = lv_indev_drv_register(&indev_main);
g = lv_group_create ();
lv_indev_set_group (enc_main_indev, g);
ui_create(g);
esp_register_freertos_tick_hook(lv_tick_task);
main_ui.c
void ui_create (lv_group_t * g)
gndbtn = lv_imgbtn_create (lv_scr_act (), NULL);
lv_obj_set_pos (gndbtn, 10, 90);
lv_imgbtn_set_src(gndbtn, LV_BTN_STATE_REL, &gnd_img);
lv_imgbtn_set_src(gndbtn, LV_BTN_STATE_PR, &gnd_toggle_img);
lv_imgbtn_set_src(gndbtn, LV_BTN_STATE_TGL_REL, &gnd_toggle_img);
lv_imgbtn_set_src(gndbtn, LV_BTN_STATE_TGL_PR, &gnd_toggle_img);
lv_obj_set_event_cb(gndbtn, event_handler_gnd);
lv_group_add_obj (g, gndbtn);
first button callback code
static void event_handler_gnd(lv_obj_t * obj, lv_event_t event)
printf("GND Event :%d \n",event);
static lv_style_t modal_style;
lv_obj_t *bobj;
lv_obj_t *gndbtn_a=NULL;
switch (event)
case LV_EVENT_FOCUSED:
lv_imgbtn_set_src(gndbtn, LV_BTN_STATE_REL, &gnd_toggle_img);
break;
case LV_EVENT_DEFOCUSED:
break;
case LV_EVENT_CLICKED:
break;
case LV_EVENT_VALUE_CHANGED:
lv_style_copy(&modal_style, &lv_style_plain_color);
modal_style.body.main_color = modal_style.body.grad_color = LV_COLOR_BLACK;
modal_style.body.opa = LV_OPA_50;
bobj = lv_obj_create(lv_scr_act(), NULL);
lv_obj_set_style(bobj, &modal_style);
lv_obj_set_pos(bobj, 10, 90);
lv_obj_set_size(bobj, 240, 145);
lv_obj_set_opa_scale_enable(bobj, true);
gndbtn_a = lv_imgbtn_create (bobj, NULL);
lv_obj_set_pos (gndbtn_a, 0, 0);
lv_imgbtn_set_src(gndbtn_a, LV_BTN_STATE_REL, &gnd_img);
lv_obj_set_event_cb(gndbtn_a, gndbtn_a_event_cb);
lv_group_focus_obj(gndbtn_a);
break;
New button callback
static void gndbtn_a_event_cb(lv_obj_t *obj, lv_event_t evt)
if(evt == LV_EVENT_VALUE_CHANGED){
lv_obj_del_async(lv_obj_get_parent(gndbtn_a));
gndbtn_a = NULL;
