How properly send text with recolor code via lv_obj_add_event_cb message
What MCU/Processor/Board and compiler are you using? ESP32-S3 on PlatformIO
What LVGL version are you using? 8.3.0 dev
What do you want to achieve? Recolor part of text send via lv_obj_add_event_cb message
I am beginner in C / C++ programing but have experience in other languages Lisp, VBA, Pascal. That’s why I a bit confused with all those types / references etc.
I have simple code which is based on some events like pushbutton, and should change something. For this exercise I want to recolor only integer value of concatenated text: Volume: #ff0000 18# or Volume: #00ff00 7# or Volume: Muted (when level is == 0)
Sending result to Serial.print gives expected results as above, but when using function it result with ? or H? rubbish on the screen. Only Volume: Muted pass OK as this is purely string.
How to properly pass those #ff0000# and other color codes.
String color_code;
cur_volume++;
cur_volume = cur_volume % 21; // 0...21
color_code = "Volume: "; // prefix
if (cur_volume == 0) {
color_code += "Muted"; // plain white
} else if (cur_volume > 0 and cur_volume < 15) {
color_code += "#00ff00 "; // green
color_code += cur_volume;
color_code += "#";
} else {
color_code += "#ff0000 "; // red
color_code += "#";
Serial.print("Color Code: ");
Serial.println(color_code);
lv_msg_send(MSG_NEW_VOLUME, &color_code);
Result in terminal:
Color Code: Volume: #ff0000 20#
Color Code: Volume: Muted
Color Code: Volume: #00ff00 1#
lv_obj_t *volume_label = lv_label_create(tileView);
lv_obj_align_to(volume_label, bat_label, LV_ALIGN_OUT_BOTTOM_LEFT, 0, 5); //align to other element on screen
lv_label_set_recolor(volume_label, true);
lv_label_set_text(volume_label, "Volume: #00ff00 10#"); // default value works too
lv_obj_add_event_cb(volume_label, update_text_subscriber_cb, LV_EVENT_MSG_RECEIVED, NULL);
lv_msg_subsribe_obj(MSG_NEW_VOLUME, volume_label, (void *)"%s");
static void update_text_subscriber_cb(lv_event_t *e) {
lv_obj_t *label = lv_event_get_target(e);
lv_msg_t *m = lv_event_get_msg(e);
const char *fmt = (const char *)lv_msg_get_user_data(m);
const char *t = (const char *)lv_msg_get_payload(m);
lv_label_set_text_fmt(label, fmt, t);
Where I am doing error?
Thanks
