I am working on a simple list menu using LVGL.
When I run the project with the SDL backend, everything looks correct.
However, when I build and run the fbdev backend for the target device, I see differences in layout and colors.
My display uses the ST7789 driver.
The framebuffer resolution is 320×240 (according to datasheet), but the physical screen is 320×170.
I configure LVGL for 320×170, and this works correctly with the SDL backend.
On the device (fbdev), the layout looks different compared to the SDL version.
Color mismatch
With the SDL backend:
background is white and buttons are blue
On the device (fbdev):
background is black and buttons are orange
I see the same color behavior when running the LVGL demo on the device.
Board: NanoPi NEO Core
Display: ST7789, 320x170, SPI
Compiler: arm-linux-gnueabihf-g++
LVGL: 9.5.0-dev
Backend: fbdev (target), SDL (host)
Device Tree:
spi@01c69000 { compatible = "allwinner,sun8i-h3-spi"; reg = <0x1c69000 0x1000>; interrupts = <0x00 0x42 0x04>; clocks = <0x04 0x1f 0x04 0x53>; clock-names = "ahb\0mod"; dmas = <0x07 0x18 0x07 0x18>; dma-names = "rx\0tx"; pinctrl-names = "default"; pinctrl-0 = <0x21>; resets = <0x04 0x10>; status = "okay"; #address-cells = <0x01>; #size-cells = <0x00>; linux,phandle = <0x66>; phandle = <0x66>; st7789@0 { compatible = "sitronix,st7789v"; reg = <0x00>; status = "okay"; spi-max-frequency = <0x4c4b400>; rotate = <0x5a>; fps = <0x3c>; buswidth = <0x08>; dc-gpios = <0x19 0x00 0x00 0x00>; reset-gpios = <0x19 0x00 0x02 0x00>; debug = <0x00>; linux,phandle = <0x67>; phandle = <0x67>; }; };
I want the fbdev output on the device to match the SDL output.
Changed resolution from 320×240 to 320×170 in:
fbdev.c
device tree
This did not solve the issue.
// Display initialization
int Display::init(uint32_t width, uint32_t height)
driver_backends_register();
/* Set window size from parameters or environment variables */
/* REMARK: settings.window_width and settings.window_height are ignored in fbdev backend */
settings.window_width = width;
settings.window_height = height;
pWidth_ = &settings.window_width;
pHeight_ = &settings.window_height;
if (driver_backends_init_backend(NULL) == -1) {
LV_LOG_ERROR("Failed to initialize display backend");
return -1;
pDisplay_ = lv_display_get_default();
if (pDisplay_ == nullptr) {
LV_LOG_ERROR("Failed to get default display");
return -1;
// Font loading (FreeType or default)
#if LV_USE_FREETYPE
pFont_ = lv_freetype_font_create(FONT_PATH, LV_FREETYPE_FONT_RENDER_MODE_BITMAP,
FONT_SIZE, LV_FREETYPE_FONT_STYLE_NORMAL);
if (pFont_ != nullptr) {
pFont_->fallback = &lv_font_montserrat_22;
} else {
pFont_ = &lv_font_montserrat_22;
#else
setupInputDevices_();
createScreens_(); // Creates all screens (main, settings, etc.)
loadScreen_(SCREEN_SETTINGS); // Load the settings screen
return 0;
// SettingsScreen constructor (called from createScreens_)
SettingsScreen::SettingsScreen(uint32_t * pWidth, uint32_t * pHeight, const lv_font_t * pFont)
: pWidth_(pWidth), pHeight_(pHeight), pFont_(pFont), pScreen_(nullptr), pButtonGroup_(nullptr)
/* Create the screen object */
pScreen_ = lv_obj_create(nullptr);
lv_obj_set_size(pScreen_, *pWidth_, *pHeight_);
lv_obj_set_style_bg_color(pScreen_, lv_color_make(0xef, 0xef, 0xef), 0);
lv_obj_set_style_bg_opa(pScreen_, LV_OPA_COVER, 0);
lv_obj_set_style_text_font(pScreen_, pFont_, 0);
/* Create the button group */
pButtonGroup_ = lv_group_create();
/* Create title container */
lv_obj_t * pTitleContainer = lv_obj_create(pScreen_);
lv_obj_set_size(pTitleContainer, lv_pct(100), lv_pct(20));
lv_obj_align(pTitleContainer, LV_ALIGN_TOP_MID, 0, 0);
lv_obj_set_layout(pTitleContainer, LV_LAYOUT_FLEX);
lv_obj_set_flex_flow(pTitleContainer, LV_FLEX_FLOW_COLUMN);
lv_obj_set_flex_align(pTitleContainer, LV_FLEX_ALIGN_CENTER, LV_FLEX_ALIGN_CENTER, LV_FLEX_ALIGN_CENTER);
lv_obj_clear_flag(pTitleContainer, LV_OBJ_FLAG_SCROLLABLE);
lv_obj_set_style_bg_opa(pTitleContainer, LV_OPA_TRANSP, 0);
lv_obj_set_style_border_width(pTitleContainer, 0, 0);
lv_obj_t * pTitle = lv_label_create(pTitleContainer);
lv_label_set_text(pTitle, "Настройки");
lv_obj_set_style_text_align(pTitle, LV_TEXT_ALIGN_CENTER, 0);
/* Create a list */
lv_obj_t * pList = lv_list_create(pScreen_);
lv_obj_set_size(pList, lv_pct(100), lv_pct(80));
lv_obj_set_pos(pList, 0, ((*pHeight_ * 20) / 100));
lv_obj_add_flag(pList, LV_OBJ_FLAG_FLOATING);
/* Create buttons */
lv_obj_t * button = lv_list_add_button(pList, LV_SYMBOL_LEFT, "Назад");
lv_obj_set_user_data(button, reinterpret_cast<void*>(SettingsButtonId::BACK));
lv_obj_add_event_cb(button, buttonHandler, LV_EVENT_CLICKED, this);
lv_group_add_obj(pButtonGroup_, button);
button = lv_list_add_button(pList, LV_SYMBOL_FILE, "Новый");
lv_obj_set_user_data(button, reinterpret_cast<void*>(SettingsButtonId::NEW));
button = lv_list_add_button(pList, LV_SYMBOL_DIRECTORY, "Открыть");
lv_obj_set_user_data(button, reinterpret_cast<void*>(SettingsButtonId::OPEN));
button = lv_list_add_button(pList, LV_SYMBOL_SAVE, "Сохранить");
lv_obj_set_user_data(button, reinterpret_cast<void*>(SettingsButtonId::SAVE));
// Additional buttons (DELETE, EDIT, BLUETOOTH, etc.) follow the same pattern...
SDL:
FBDEV:
P.S.
My guess is that I may be using pWidth_ and pHeight_ incorrectly during initialization, which could explain the layout differences.
However, this does not explain the color mismatch.
Any clarification would be helpful.
