I am migrating from v8.4 to v9.3 in v8.4 I can scroll the canvas by using lv_canvas_transform.
So the source and destination is the same canvas. I use an extra buffer to copy the previous canvas minus 1 line and copy it using lv_canvas_transform to the new position. This works quite well and fast.
However in v9 there is no lv_canvas_transform, the examples show the use of a 2nd canvas and an image object. However when I try this it is very slow and does not give the same result.
Is there a more easy and performing way to copy to and from a canvas in v9.3?
memcpy(buf.data(), cbuf.data() + LV_CANVAS_BUF_SIZE_TRUE_COLOR(width, 1), LV_CANVAS_BUF_SIZE_TRUE_COLOR(width, height - 1));
img.data = (uint8_t *)buf.data();
img.header.cf = LV_IMG_CF_TRUE_COLOR;
img.header.w = width;
img.header.h = height - 1;
lv_canvas_transform(canvas, &img, 0, LV_IMG_ZOOM_NONE, 0, 0, width, height - 1, true);
In v9.3 I try the following but does not look ok to me. There should an easy way to copy to and from the canvas
lv_obj_t *canvas_temp_buffer = lv_canvas_create(obj_parent);
lv_canvas_set_buffer(canvas_temp_buffer, temp_buffer.data(), width, height - 1, LV_COLOR_FORMAT_NATIVE);
//lv_canvas_fill_bg(canvas_temp_buffer, lv_color_black(), LV_OPA_COVER);
lv_obj_set_pos(canvas_temp_buffer, _x, _y + 1);
lv_layer_t layer;
lv_canvas_init_layer(canvas_temp_buffer, &layer);
lv_image_dsc_t img;
lv_draw_buf_to_image(lv_canvas_get_draw_buf(canvas_temp_buffer), &img);
lv_draw_image_dsc_t img_dsc;
lv_draw_image_dsc_init(&img_dsc);
img_dsc.src = &img;
lv_area_t coords_img = {0, 1, width, height - 1};
lv_draw_image(&layer, &img_dsc, &coords_img);
raspberry pi linux
lvgl v9.3
