Scroll snap center
I want snap a child in a scroll window y center when scroll end, every time.
how I can do that?
V9.2
/** creat a scroll window */
	obj_window_roller = lv_obj_create(ui_obj_device_page);
	lv_obj_set_style_bg_color(obj_window_roller, lv_color_hex(0x778899), LV_PART_MAIN | LV_STATE_DEFAULT);
	lv_obj_set_style_bg_opa(obj_window_roller, UI_BTN_OPA, 0);
	lv_obj_set_size(obj_window_roller, 200, 300);
	lv_obj_set_pos(obj_window_roller, 200, 90);
	lv_obj_set_style_border_width(obj_window_roller, 0, 0);
	lv_obj_set_style_pad_all(obj_window_roller, 0, 0);
	lv_obj_set_style_radius(obj_window_roller, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
	//lv_obj_align(obj_window, LV_ALIGN_CENTER, 0, -10);
	lv_obj_set_flex_flow(obj_window_roller, LV_FLEX_FLOW_COLUMN);
	lv_obj_set_flex_align(obj_window_roller, LV_FLEX_ALIGN_CENTER, LV_FLEX_ALIGN_CENTER, LV_FLEX_ALIGN_CENTER);
	lv_obj_add_flag(obj_window_roller, LV_OBJ_FLAG_SCROLL_ELASTIC);
    //lv_obj_add_flag(obj_window_roller, LV_OBJ_FLAG_SCROLL_ONE);
	lv_obj_set_scroll_dir(obj_window_roller, LV_DIR_VER); //
	lv_obj_set_scroll_snap_y(obj_window_roller, LV_SCROLL_SNAP_CENTER); //
	lv_obj_set_style_pad_gap(obj_window_roller, 4, LV_PART_MAIN); //
	lv_obj_set_scrollbar_mode(obj_window_roller, LV_SCROLLBAR_MODE_ON); //
	lv_obj_add_event_cb(obj_window_roller, water_injection_vertical_roller_event_cb, LV_EVENT_SCROLL, NULL); //
	/** fill number */
	float i;
	char buf[8];
	lv_obj_t *vertical_roller_btn;
	lv_obj_t *vertical_roller_btn_label;
	for (i = 18; i <= 28; i = i + 0.5) {
		vertical_roller_btn_label = lv_label_create(obj_window_roller);
		lv_obj_remove_style_all(vertical_roller_btn_label);
		lv_obj_add_flag(vertical_roller_btn_label, LV_OBJ_FLAG_SNAPPABLE);
		sprintf(buf, "%.1f", i);
		lv_label_set_text(vertical_roller_btn_label, buf); //
		lv_obj_set_style_text_font(vertical_roller_btn_label, ui_font_get(HIDC_Numeral_R, 40), LV_PART_MAIN);
See this example: Examples — LVGL documentation
if just Translate position (x), seem good.
when change the font size and the position(x), not good
My scroll snap widget also has this issue. I set every label height with biggest label height to solve this issue, and it seems good.
The font size of the text is different, so the line spacing between the words will be large?
