I found a solution, but maybe there is a better one. Let me know, if you will find one.
Here is my code:
#include <lvgl.h>
//#include <Arduino.h>
#include <HardwareSerial.h>
#define TFT_BL 2
#define SCREENSAVER_TIMEOUT 5000 // 5 Sekunden in ms
#define SCREEN_OFF_TIMEOUT 5000 // 5 Sekunden in ms
#define MAKE_OBJ_CLICKABLE_DELAY 300
#if defined(DISPLAY_DEV_KIT)
Arduino_GFX *gfx = create_default_Arduino_GFX();
#else
Arduino_ESP32RGBPanel *bus = new Arduino_ESP32RGBPanel(
GFX_NOT_DEFINED /* CS */, GFX_NOT_DEFINED /* SCK */, GFX_NOT_DEFINED /* SDA */,
40 /* DE */, 41 /* VSYNC */, 39 /* HSYNC */, 42 /* PCLK */,
45 /* R0 */, 48 /* R1 */, 47 /* R2 */, 21 /* R3 */, 14 /* R4 */,
5 /* G0 */, 6 /* G1 */, 7 /* G2 */, 15 /* G3 */, 16 /* G4 */, 4 /* G5 */,
8 /* B0 */, 3 /* B1 */, 46 /* B2 */, 9 /* B3 */, 1 /* B4 */
Arduino_RPi_DPI_RGBPanel *gfx = new Arduino_RPi_DPI_RGBPanel(
bus,
800 /* width */, 0 /* hsync_polarity */, 8 /* hsync_front_porch */, 4 /* hsync_pulse_width */, 8 /* hsync_back_porch */,
480 /* height */, 0 /* vsync_polarity */, 8 /* vsync_front_porch */, 4 /* vsync_pulse_width */, 8 /* vsync_back_porch */,
1 /* pclk_active_neg */, 14000000 /* prefer_speed */, true /* auto_flush */);
#include "touch.h"
static uint32_t screenWidth;
static uint32_t screenHeight;
static lv_color_t *disp_draw_buf;
#if (LV_COLOR_16_SWAP != 0)
gfx->draw16bitBeRGBBitmap(area->x1, area->y1, (uint16_t *)&color_p->full, w, h);
#else
gfx->draw16bitRGBBitmap(area->x1, area->y1, (uint16_t *)&color_p->full, w, h);
lv_disp_flush_ready(disp);
static lv_timer_t *screensaver_timer;
static lv_timer_t *screen_off_timer;
static lv_timer_t *make_obj_clickable_timer;
static bool screensaver_active = false;
static bool screen_off_active = false;
static lv_obj_t *btn;
static lv_obj_t *label;
static lv_obj_t *src_layer;
void make_obj_clickable_cb(lv_timer_t *timer)
lv_timer_reset(make_obj_clickable_timer);
lv_timer_pause(make_obj_clickable_timer);
Serial.println("clickable");
lv_obj_add_flag(btn, LV_OBJ_FLAG_CLICKABLE);
void reset_screensaver_timer(void)
Serial.println("Reset_Funktion");
if (screensaver_active || screen_off_active)
lv_timer_resume(make_obj_clickable_timer);
ledcWrite(0, 255); // Helligkeit auf Maximum setzen
Serial.println("255_Prozent");
lv_timer_reset(screensaver_timer);
lv_timer_reset(screen_off_timer);
lv_timer_pause(screen_off_timer);
lv_timer_resume(screensaver_timer);
void my_touchpad_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data)
if (touch_has_signal())
if (touch_touched())
data->point.x = touch_last_x;
data->point.y = touch_last_y;
Serial.println("Aufruf Reset screensaver");
reset_screensaver_timer();
else if (touch_released())
void screensaver_cb(lv_timer_t *timer)
screensaver_active = true;
ledcWrite(0, 100); // Helligkeit auf 100 (von 255) reduzieren
lv_timer_reset(screen_off_timer); // Startet den Timer für den vollständigen Ausschaltmodus
lv_timer_resume(screen_off_timer);
// lv_obj_clear_flag(btn, LV_OBJ_FLAG_CLICKABLE);
lv_timer_pause(screensaver_timer);
Serial.println("100_Prozent");
void screen_off_cb(lv_timer_t *timer)
Serial.println("OFF_Funktion");
if (screensaver_active && !screen_off_active)
screen_off_active = true;
ledcWrite(0, 0); // Helligkeit auf 0 setzen, um die Hintergrundbeleuchtung auszuschalten
Serial.println("0_Prozent");
void setup()
Serial.begin(9600);
Serial.println("LVGL Widgets Demo");
gfx->begin();
#ifdef TFT_BL
pinMode(TFT_BL, OUTPUT);
digitalWrite(TFT_BL, HIGH);
ledcSetup(0, 300, 8);
ledcAttachPin(TFT_BL, 0);
gfx->fillScreen(BLACK);
delay(100);
pinMode(TOUCH_GT911_RST, OUTPUT);
digitalWrite(TOUCH_GT911_RST, LOW);
delay(10);
digitalWrite(TOUCH_GT911_RST, HIGH);
delay(10);
touch_init();
screenWidth = gfx->width();
screenHeight = gfx->height();
#ifdef ESP32
disp_draw_buf = (lv_color_t *)heap_caps_malloc(sizeof(lv_color_t) * screenWidth * screenHeight / 4, MALLOC_CAP_INTERNAL | MALLOC_CAP_8BIT);
#else
disp_draw_buf = (lv_color_t *)malloc(sizeof(lv_color_t) * screenWidth * screenHeight / 4);
if (!disp_draw_buf)
Serial.println("LVGL disp_draw_buf allocate failed!");
lv_disp_draw_buf_init(&draw_buf, disp_draw_buf, NULL, screenWidth * screenHeight / 4);
lv_disp_drv_init(&disp_drv);
disp_drv.sw_rotate = 1;
lv_disp_set_rotation(NULL, LV_DISP_ROT_90);
// Erstelle den src-Layer für normale Inhalte
src_layer = lv_obj_create(lv_scr_act());
lv_obj_set_size(src_layer, LV_HOR_RES, LV_VER_RES);
lv_obj_set_style_bg_color(src_layer, lv_color_hex(0xFFFFFF), LV_PART_MAIN); // Setze Hintergrundfarbe
// Erstelle den Button im src-Layer
btn = lv_btn_create(src_layer);
lv_obj_set_size(btn, 120, 50); // Größe des Buttons festlegen
lv_obj_align(btn, LV_ALIGN_CENTER, 0, 0); // Button in der Mitte des Bildschirms positionieren
label = lv_label_create(btn); // Label für den Button erstellen
lv_label_set_text(label, "Test Button"); // Text des Labels festlegen
lv_obj_center(label); // Label im Button zentrieren
screensaver_timer = lv_timer_create(screensaver_cb, SCREENSAVER_TIMEOUT, NULL);
screen_off_timer = lv_timer_create(screen_off_cb, SCREEN_OFF_TIMEOUT, NULL);
make_obj_clickable_timer = lv_timer_create(make_obj_clickable_cb, MAKE_OBJ_CLICKABLE_DELAY, NULL);
ledcWrite(0, 255);
void loop()
lv_task_handler();
lv_timer_handler();
delay(5);
