stm32
v 7.11
screen transition with more than 2 structures
I made back button to turn back to the previous screen, and the home button to go back to the main (first) screen.
I went from the first screen to the second screen, and then from the second screen to the third screen.
I can go from the third screen to the second screen, but I can’t go to the first screen from the second screen by pressing the back button again.
The screens are randomly freezing after I pushed the back button several times.
I made 11 screens and there is 4~5 depth.
And I wonder which is correct or much better:
- use lv_scr_load and load the previous screen
- call the function that creates and calls the corresponding screen
// the function is called when the back button pressed
static void back_btn_touched_cb(lv_obj_t * btn, lv_event_t event)
if(event == LV_EVENT_PRESSED && event != LV_EVENT_GESTURE)
// I made the back button on several screens,
// I checked which screen is on.
current_scr = lv_obj_get_screen(lv_back_btn);
if(current_scr == second_scr)
// first_screen_on();
lv_scr_load(first_scr);
else if(current_scr == third_scr)
// second_screen_on();
lv_scr_load(second_scr);
else if(current_scr == fourth_scr )
//third_screen();
lv_scr_load(third_scr);
const char * screen_name = lv_obj_get_user_data(current_scr);
printf("The current screen is %s\r\n", screen_name ? screen_name : "N/A");
//lv_obj_clean(current_scr);
after on the 3rd screen, I cannot go to the 1st screen, even though I’ve already come to the 2nd from the 3rd. The back button suddenly doesn’t work.
