I try to rotate the display in the same orientation as the touchscreen. When I use the lv_display_set_rotation() function, my display is rotated, but the screen width is truncated to 240 pixels, while it should be 320 pixels. In fact, I’m getting a 240 x 240 display. When I use the corresponding TF_eSPI function tft.setRotation(), the display rotation is performed as expected.
I tried different rotation settings. The content of the display is rotated as required, but the display is always 240x240.
CYD = ESP32 with XPT2046 touch controler and ILI9341 display controller
9.2
support rotation in all 4 orientations
see description section
I also tried without swapping height and width in the #define section, but the result is the same.
#define LV_DISPLAY_ROTATION_0 0 // portrait, USB bottom side
#define LV_DISPLAY_ROTATION_90 1 // landscape, USB right side
#define LV_DISPLAY_ROTATION_180 2 // portrait, USB top side
#define LV_DISPLAY_ROTATION_270 3 // landscape USB left side
#define TFT_ROTATION LV_DISPLAY_ROTATION_90 // landscape, USB right side
// swap height and width according to rotation setting
#if (TFT_ROTATION == LV_DISPLAY_ROTATION_0) || (TFT_ROTATION == LV_DISPLAY_ROTATION_180)
#define SCREEN_WIDTH 240
#define SCREEN_HEIGHT 320
#else
#define SCREEN_WIDTH 320
#define SCREEN_HEIGHT 240
… some more code
in setup function:
touchscreen.begin(touchscreenSPI);
touchscreen.setRotation(TFT_ROTATION);
… some more code …
disp = lv_tft_espi_create(SCREEN_WIDTH, SCREEN_HEIGHT, draw_buf, sizeof(draw_buf));
// lv_display_set_rotation(disp, (lv_display_rotation_t)TFT_ROTATION); // use LVGL lib to set rotation doesn’t work!
tft.setRotation(TFT_ROTATION); // use TFT lib to set rotation
