I am writing code for esp32s3 lvgl display 5 inch. Everything is working good but i found a screen flickering issue while writing data on eeprom. EEPROM.commit(); this line is making the issue. I am stuck here. My code is finish. Could anyone solve this problem. Thanks.
Probably the Espressif guys can tell more how EEPROM and the screen interference with each other. I suggest opening an issue here.
Hi, Have you managed to find a simple or more complex
) solution to the problem? I’ve also hit a wall, and none of the known methods seem to work, so it really does seem like a hardware issue.
You and muzahid same level , no info in question = no solution.
